FS: Project KicsR40 lug nuts w/ locks
Old Aug 4, 2009 | 03:31 AM
IS300na-t's Avatar
Up for sale are Project Kics lugs nuts WITH locks. Ive only used these once to test them, but no longer need them. These retail for around $250. Im letting these got for $175
Here is the product description and a picture of them.
Project Kicks R40 Racing Composite lug nuts are a patented 2 piece design that allows the top of the lugs to spin independently from its tapered end. This innovative design provides the best hold than any lug nuts on the market today. Its tapered end greatly reduces the changes of scratching your wheels. Made of lightweight composite materials. These seven sided lugs come in a set of 16 with 4 locks, key, and weights under 2 lbs. Use only the best designed by the best of Japan. Use only the best designed by the best of Japan.
* Super light-weight thin-wall construction using strong light-weight OEM quality materials.
* Oversized and taper seat to ensure best contact.
* External drive by popular 17mm hex for easier installation.
* Full stud engagement and can accommodate long racing studs.
* Reliable and stronger than aluminum racing nuts.
* Japan patented (No. 1192260) and USA patent (No. D510259)
* Lug body produced by Cold-Forged SCM-435 material.
* Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish.
Old Aug 4, 2009 | 05:37 PM
IS300na-t's Avatar
Sold!!!!!!!
EightyFour
Feb 18, 2017 10:42 PM
Jus Garcia
Jan 5, 2014 05:52 PM
dewthedew
Dec 17, 2012 05:26 PM
Nikkaeman
Jun 4, 2011 04:43 PM
Spyderfenix
18
Dec 22, 2010 05:40 PM
