winter tires on the Sport
Old Nov 5, 2006 | 03:23 PM
Jonavin's Avatar
What do you think is better. Stock size of 195/55x15 or minus one size of 175/65x14? Skinner is generally better for snow, but handling in the dry won't be as good.
Old Nov 5, 2006 | 05:04 PM
LiL Wee FIT's Avatar
I would actually do 185/60R15.
Although it won't be as cheap as 14", but tires will be cheaper than 195/55R15. The difference between the two 15" sizes are less than 2%. The general rule of thumb is that anything less than 3% will not make much of a difference on your speedo.
As for why I would use 15" instead of 14's? Well... "just incase" i want to upgrade my brakes for watever reasons. Also cause 15" looks a 'tiny' bit better than 14's.
So depending if those 'benefits' matter much to you, if not, 14" would be better overall.
Hope this helps!
-Sherman
Old Nov 5, 2006 | 05:50 PM
JonasM's Avatar
I stuck with the same size as stock, adjusted for rim size - 185/65R14 (since I'm using my old Civic rims).
JonasM
Old Nov 5, 2006 | 06:02 PM
Jonavin's Avatar
I haven't even thought of the 185/60x15 size. Those are good points.
Old Nov 5, 2006 | 07:57 PM
JDMish's Avatar
plus 185/60 has more tire choices for winter tires
Old Nov 5, 2006 | 11:58 PM
RageOfFury's Avatar
I just went with the original Sport tire and wheel size.
Old Nov 23, 2006 | 04:06 PM
Jonavin's Avatar
I decided to go with 185/65 14 instead, just because of availability of tire sizes. We barely had our first snow in Toronto this week (nothing stays on the ground) and tire stores are all very busy. I hate to wait until the first real snowfall to try and get tires.
Old Nov 23, 2006 | 05:13 PM
b17gsr's Avatar
I have 185/65R14 Nordic Icetracs on 99 Civic steelies. no clearance issues.
Old Nov 25, 2006 | 04:06 PM
Battleendless's Avatar
yeah man 14" viking running low in stock now...better to do it before the first snow
Old Dec 1, 2006 | 01:23 AM
Bounty Hunter's Avatar
It looks like 185/65/14 is the ideal size for Sport owners to step down to 14" if you look at the tire/wheel size calculators.
I'm still trying to decide if I'm going to go with the winter tires to fit my Integra GSR wheels or step down to 14's. The cost of 195/55/15 winter tires are about as much as summer performance tires.
Old Dec 1, 2006 | 07:21 AM
Do 185/60R15
Cost much less than 195/55R15.. so then, you can run your GSR wheels for winter!
Old Dec 1, 2006 | 08:49 AM
sillypuddy's Avatar
Someone that Posts too much
the price difference between 14" and 15" and the various tire sizes, when i checked, was only about $20-$40CAD for a set so it's not alot
with that said, i went with stock 195/55-15 sized toyo snows, and they are very good in snow
lil wee fit: 14/15 is not going to matter, since any big brake will require at least 16s and lower offset rims.. you won't be able to use stock or steeles
-joe
Ryu69
Apr 24, 2024 09:33 AM
YWGjets
Nov 3, 2011 03:32 PM
1x1
Oct 27, 2010 07:24 PM
saralee
Nov 15, 2007 11:08 PM
YeeFit
Aug 30, 2007 08:36 AM
