Sponsored by:
Sponsored by:
How to fix scratch/scraped alloy wheels
Old 07-13-2011, 12:34 AM
Ric01's Avatar
I turned the corner too sharply too close to the curb and my FIT Rear right allow rim was scape /scratched quite deeply exposing about 2 inches of bare aluminum at the edge. Luckily, my spokes are OK
I applied multiple layers of alloy waxing compound (used to polish alloy wheets) hopefully to minimize oxidation of the exposed aluminum.
Any ideas to prevent further oxidation of the affected area, short of buying a new alloy wheel?
Thanks
Old 07-13-2011, 08:06 AM
Brooksy's Avatar
If the scratch isn't too deep just smooth it out with a bit of sandpaper and retouch the paint with a matching silver then apply a coat of clear laquer.
Old 07-13-2011, 08:32 AM
acreativename's Avatar
There are also companies that repair aluminum wheels. They can repair scrapes, bends, even some cracks! If you don't want to suffer that expense, I have seen some pretty good jobs done repairing wheels with body filler and paint. Obviously only do that for cosmetic problems, not anything structural.
Old 07-13-2011, 12:17 PM
you can clean the metal and clearcoat it (just use enamel clear coat, even your nail polish clear will work) or have it repaired at a wheel repair shop.
im not sure where you'd go in canada but in the US there are many wheel repair shops that can match factory paint.
Old 07-13-2011, 05:28 PM
Chad T's Avatar
If it's a silver painted factory wheel just sand the rough spots and use some bright silver touch up paint.
I got sideswiped in my '09 Fit and was able to make the wheel look decent with very little effort. Actually I don't think I even sanded it. Just cleaned off the tire smears from the other car.
Old 07-13-2011, 08:50 PM
roguenode's Avatar
Here's a couple of DIY wheel repair links. They may be a bit more than you need to do, but probably worth a look.
Wheel Refurb - - Detailing World -
Refurbing & Spraying Alloy Wheels... - - Detailing World -
Old 07-13-2011, 11:45 PM
Ric01's Avatar
Thanks to all for all your great ideas...great stuff!
DannyBoy7783
09-27-2016 10:13 PM
jnesselroad
03-12-2011 11:28 AM
thefit09
06-21-2010 06:37 PM
cr4zy3lgato
06-01-2010 11:24 PM
NEK FIT
10-14-2008 10:33 PM
Quick Reply: How to fix scratch/scraped alloy wheels
