Acura CL Maplights w/Homelink install
Old Nov 7, 2006 | 11:41 PM
JDM's Avatar
JDM
Here are some pics and a quick post of what I did....
First, made a template and cut out the liner..
Then,
I measured up the bracket in order to mount the unit. I used the cut out from the liner as padding in the back and secured it onto the roof with some 3M doubled sided tape.
I recommend using some the 3M tape that is used with securing body kits, it is black with red lining.
Next step is to solder the wires onto the unit if you are not going to use the stock harness from Acura.
Here is a diagram to help out with wiring the power and ground...
Then after soldering the wires I ran the power to the dome light...
Connect the power to the "White" wire and the ground to one of the rear view mirror screws.
Before securing everything make sure all lights work and that the Homelink has power and you are done.
I have to thank b17gsr (Eric) for helping me out and this was all his idea!!
Sorry for the poor pics. I was using my camera phone.
Thanks.
Old Nov 7, 2006 | 11:44 PM
aziatiklover's Avatar
Master FitFreaker
thats dope man.....
Old Nov 7, 2006 | 11:51 PM
JDM's Avatar
JDM
Thanks man
Old Nov 7, 2006 | 11:54 PM
LiL Wee FIT's Avatar
Wow.. thanks for the awesome howto!
Old Nov 8, 2006 | 12:07 AM
JDM's Avatar
JDM
Thanks Lil Wee!
Here is a "How to" for programming the Homelink system.
http://www.homelink.com/training/vid...clude=gdo_main
Enjoy!
Old Nov 8, 2006 | 01:41 AM
koolkevin1107's Avatar
OH EM EF GEE!! i have one of these in my room that i was gonna install in my civic. i had a question....does it bolt on?!?!?!! it looks like the bolt holes for the maplight will bolt straight up to the holes on the metal bar?? please can u confirm this? how did u mount it??? omfg i want it!! i need friggin map lights!
Old Nov 8, 2006 | 01:47 AM
JDM's Avatar
JDM
It does not bolt on directly. You'll need to use the Acura CL bracket and secure it the the body. I used the cut out from the liner to act as a "shim" to sandwich it in firmly. I was actually going to use some "JB Weld" to mount the bracket onto the roof of the car. By using the bracket it prevents the unit from moving and falling out.
Old Nov 8, 2006 | 02:08 AM
oh i see now. so that metal bracket that is in the headliner is the cl bracket it is not found stock in our cars....see i don't have that part. =[
Old Nov 8, 2006 | 03:47 AM
JDM's Avatar
JDM
You can probably pick one up at the junk yard or call the dealer to see how much that part costs.
Old Nov 8, 2006 | 09:01 AM
sillypuddy's Avatar
Someone that Posts too much
what year CL did the homelink come out of?
-joe
Old Nov 8, 2006 | 09:10 AM
sillypuddy's Avatar
#11?
-joe
Old Nov 8, 2006 | 11:43 AM
b17gsr's Avatar
IIRC, mine was from a 99 CL, and I was too lazy to source the bracket. If you plan on installing the JDM roof console, you need to mount the map lights closer to the rear view mirror.
It's not hard, the first cut is the scariest.
Now that winter is fast approaching, I'm using the map lights a few times per week, and the Homelink even more!
Old Nov 8, 2006 | 01:02 PM
JDM's Avatar
JDM
-joe
Its from a 99 Acura CL. I found it on Ebay for $25.
Old Nov 8, 2006 | 01:44 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
thats awesome.. looks stock!
Old Nov 20, 2006 | 09:33 PM
sillypuddy's Avatar
can i ask how you attached the unit without the bracket? i got my CL map light off ebay and it didn't come with the bracket
also, which wire do i connect in the dome light to get power?
-joe
Old Nov 21, 2006 | 09:58 AM
b17gsr's Avatar
I fabbed a bracket with two of those 8" long brackets used for mounting aftermarket decks. I bent them like an upside down "V", and the tips of the V are against the headliner. I bent the tips a bit to prevent them from ripping through the liner.
As for wiring to the dome light, I used a voltmeter to locate it. I can't recall which of the two wires I tapped into.
Old Nov 21, 2006 | 10:34 AM
sillypuddy's Avatar
thanks
-joe
Old Nov 21, 2006 | 03:20 PM
wyy183's Avatar
If memory serves right, it is the red wire with the white stripe, which is the center wire in the three-pin connector, that only has two wires going to it!!
Old Nov 21, 2006 | 03:22 PM
sillypuddy's Avatar
i can just use one of those clip on taps?
-joe
Old Nov 21, 2006 | 05:25 PM
b17gsr's Avatar
If you want too, sure.
