Honda Emblems, RED emblems, CF emblems, emblems questions
Old Nov 15, 2006 | 01:51 PM
  #161
JamesBizzle's Avatar
Originally Posted by B2L2
Question here for removing the rear badge. Am I suppose to "break" away the 2 pins behind the rear badge before pulling the badge out?
I followed FitSport's approach and I could see the 2 pins. I'm just not sure whether I should push the 2 pins out or "break" them instead.
Thanks,
- Brian
yup, break them. don't be scared to slap the butt of the driver hard so that the tip of it breaks the pins. it's a very simple process and you won't mess anything up as long as you're carefull.
Old Nov 19, 2006 | 01:13 AM
  #162
vince's Avatar
does anyone have a picture of a black fit with the jdm emblem? I want to see how it will look like if i decided to do that =p. I'd greatly appreciate it. THANK YOU!
Old Nov 19, 2006 | 09:12 AM
  #163
sillypuddy's Avatar
Someone that Posts too much
google is your friend..
-joe
Old Nov 19, 2006 | 06:40 PM
  #164
fitoromocto's Avatar
Where did you order yours emblem and how much if you dont mind me asking.
Look good..
Old Nov 19, 2006 | 07:23 PM
  #165
Mugen_Dom's Avatar
Look good..
A&J have it for just under CDN$50
http://www.aj-racing.com/catalog/pro...&cat=60&page=2
Old Nov 19, 2006 | 07:25 PM
  #166
sillypuddy's Avatar
fitoromocto, whereabouts are you?
-joe
Old Nov 20, 2006 | 06:12 PM
  #167
Fredericton / Oromocto N-B
Storm Silver Sport MT
Old Jan 16, 2007 | 06:58 PM
  #168
ashsblrsxtrg2006's Avatar
help with jazz emblem installation
i have a us honda fit and i want to get the jazz emblem on it. does anybody know how to safely remove the fit emblem and replace it with the jazz one?
Old Jan 16, 2007 | 07:31 PM
  #169
Fit of RAGE's Avatar
all you need is a heat gun and/or blow dryer and just heat up the emblem. (they are taped on) then, VERY carefully, use a NEW razor blade (AT YOUR OWN RISK) and gently cut one corner off of the emblem between the emblem and the trunk. After you cut enough for your hand to grab on to, SLOWLY peel teh emblem off. Then just take some cleaner and take off the residue. I did this with my 4Runner and it took about 2 minutes. If you are using a heat gun, DO NOT heat up the paint. Keep the blow dryer/heat gun CONSTANTLY moving!!!
Old Jan 17, 2007 | 08:58 AM
  #170
Originally Posted by claymore
Or instead of the razor blade just get a piece of DENTAL FLOSS and slide it under one corner and just like flossing drag the floss behind the badge.... No chance of paint damage.
yeah, that's probably a better and safe idea!!
Old Jan 17, 2007 | 10:56 AM
  #171
rcantu's Avatar
yes floss or a PLASTIC putty knife.
Old Jan 17, 2007 | 03:36 PM
  #172
wat happens if i change it and then i get pulled over and the cop finds out that its not a jazz but a fit? would i get in trouble for that?
Old Jan 28, 2007 | 12:26 PM
  #173
fits_all's Avatar
Where 2 get Jdm emblem
getting this post straight, in ebay theres a sale for "red dot fit emblem" but the guy told me its aftermarket and not "jdm". To my understanding, in Japan it comes like this factory. Anyone knows where I can get this, or is it really an aftermarket emblem?
Old Jan 28, 2007 | 04:52 PM
  #174
the link doesn't work
Old Jan 29, 2007 | 07:28 AM
  #175
fits_all's Avatar
YUP I know, the way to post pics in here is kinda f'ed. might try it in here
eBay Motors: HONDA FIT EMBLEM WITH RED DOT, CIVIC, ACCORD (item 150025469173 end time Feb-17-07 14:28:47 PST)
Old Feb 18, 2007 | 04:52 PM
  #176
firstshadow's Avatar
Senior Member
jdm H emblems besides red?
i found a site with silver, black, and white H emblems... it says for s2000 but would they fit on the fit?
Old Feb 18, 2007 | 09:18 PM
  #177
JDMchris.com's Avatar
I run THIS
im sure they would fit....... however they wouldnt fit good..... the S2000 emblems are ALOT smaller than the fit ones.
Old Feb 18, 2007 | 10:03 PM
  #178
Deivioncrx's Avatar
idk about the front one but the rear would be eazy, just pop off the stock emblem, trace around it, then find some vinyl in whatever color you want, and cut out a piece the size of the emblem, then just stick it on under the emblem, you can peel it back off anytime you want to, and it shouldnt cost more than a few bucks. the front is a different story, you probably would have to remove the chrome H, tape off and paint the black plastic behind it whatever color, then pop the H back on it.
Old Feb 19, 2007 | 09:07 AM
  #179
Yup, i made my own Carbon Fiber rear "H" emblem.
Mind you it was raining when i did it so it looks really dirty and scratched up, but here it is:
Old Feb 19, 2007 | 05:30 PM
  #180
Senior Member
i wonder if there are ones somewhere around that will fit the fit perfectly lol that would rock, id want to get the silver or black ones.
