Acura CL Maplights w/Homelink install
Old Nov 27, 2006 | 08:17 PM
eGadgetGeek's Avatar
Originally Posted by b17gsr
IIRC, mine was from a 99 CL, and I was too lazy to source the bracket. If you plan on installing the JDM roof console, you need to mount the map lights closer to the rear view mirror.
It's not hard, the first cut is the scariest.
Now that winter is fast approaching, I'm using the map lights a few times per week, and the Homelink even more!
b17gsr, Did you have a block of foam between the headliner and the roof? I was inspecting mine before I get ready to make the cuts and notice a block of dense foam where the light will go. Should make a difference just curious if you had the same thing.
Old Nov 28, 2006 | 07:00 AM
sillypuddy's Avatar
Someone that Posts too much
my dad saw this post and did the install in my fit
he noticed the block of foam, and basically positioned the map light so that he can take out the block of foam.. he then split the block of foam in half, use it to prop up front and back of the hole so that when you push on the homelink buttons, it's still supported
on my odysessy, when the doors open, the map lights turn on.. is that what the middle pin is for?
-joe
Old Nov 28, 2006 | 07:14 AM
spider2k's Avatar
ones constant 12v, ones ground and the other will be negative switched from the door circuit to trigger the lights when you open the door. just tie it into the existing dome light.
Old Nov 28, 2006 | 08:08 AM
-joe
I kind of figure that was the case. I was thinking about hollowing it out so the light would fit in it but it would be quicker to cut it in half. Did he say whether it was glued in place or not?
Steve.
Old Nov 28, 2006 | 08:26 AM
sillypuddy's Avatar
it was glue to the head liner..
the block was only about 1.5" x 1.5" x 8" so you wont' be able to "hollow" it out :-)
thanks for the tip about the door light
-joe
Old Nov 28, 2006 | 01:26 PM
b17gsr's Avatar
When I plugged my CL unit in my Odyssey to test it, it didn't turn the lights on with the doors. Maybe the CL uses a positive trigger instead of negative?
As for the foam, I used the parts supplied with the overhead console.
Old Nov 28, 2006 | 02:43 PM
sillypuddy's Avatar
you actually bought a new console? they are expensive.. unless you didn't get homelink with yours?
-joe
Old Nov 28, 2006 | 08:11 PM
I tested my light this evening with a battery to make sure everything worked. The switched lights come on with the two outside pins powered. When you take the center pin to ground it lights the lights as long as they aren't already turned on. So, this would mean they are negative switched from the door circuit. Haven't pulled the dome light yet to see how it is wired.
My light came only with the light, no bracket was included. Time to fabricate one.
Old Nov 28, 2006 | 08:17 PM
sillypuddy's Avatar
damn man
i should have asked before i closed everything up.. now i have to drag another wire to the console :-)
-joe
Old Nov 29, 2006 | 10:55 AM
b17gsr's Avatar
The JDM roof console.
Damn, I'll have to retest that negative trigger...
Old Nov 29, 2006 | 07:41 PM
uiskibum's Avatar
this is somewhat on topic, for those that have installed the homelink from a CL; do you have an opener with rolling codes, and does it work.
Thanks!
Old Nov 29, 2006 | 07:52 PM
  #32
Adrenergic1's Avatar
thats awesome, good job! i'm going to have to keep this in mind.
Old Nov 29, 2006 | 10:06 PM
  #33
sillypuddy's Avatar
yes it works
you need to get rolling code instructions for the programming
-joe
Old Nov 29, 2006 | 11:31 PM
  #34
b17gsr's Avatar
My CL map lights refuse to work with that middle negative trigger. GRRR...
Old Nov 30, 2006 | 07:52 AM
  #35
I was able to get my Homelink to work with my garage door opener on the middle button. Couldn't get it to work on the first button by following the Homelink programming instructions. Once I get it installed I'll play with it some more. I have a wireless X-10 starter setup from Rat Shack that I bought about 7 years ago to play around with. Maybe I'll finally get to use it for something.
Old Nov 30, 2006 | 07:54 AM
  #36
Does your Homelink work? If so, then you have the polarity correct on your current setup. I noticed when I was playing around with mine testing it out that the light would light no matter which way the battery was hooked up but the Homelink needed it to be one way. Just a thought.
Old Nov 30, 2006 | 10:07 AM
  #37
b17gsr's Avatar
Homelink works fine. Odds are something internal is screwy. No biggy, I don't need that much lighting when I get into my Fit.
Old Nov 30, 2006 | 10:17 AM
  #38
sillypuddy's Avatar
did you reset your homelink and then reprogram the buttons?
-joe
Old Nov 30, 2006 | 10:40 AM
  #39
How do you reset it? I didn't see that on the Homelink website.
Old Dec 7, 2006 | 06:54 PM
  #40
jsmonet's Avatar
yes it works
-joe
with most setups all you do is train the homelink as usual (click the clicker while doing the weirdy dance on your head singing honda is great, etc etc), then you go to your garage door opener and have it accept your homelink as a trigger. break out your manual and look up how to add new remotes.
this, effectively, sets your opener to respond to one static code. homelink devices don't have the ability to mimic a rolling code so this is the workaround. with non-rolling-code setups you wouldn't have to program your opener, it would just respond thinking your homelink IS your old remote.
