Photo Requests, Photoshop Requests
Old Aug 24, 2006 | 11:07 AM
  #121
Fittogo's Avatar
Originally Posted by trowpa
Also - if the overall wheel size stays the same, what causes the rubbing issues people w/ 17inch rims report?
Wrong offset or wheel/tire too wide.
Old Aug 24, 2006 | 11:25 AM
  #122
Illusive's Avatar
Small changes in the diameter will not throw off your speedometer enough for you to worry. The offset will determine whether or not your wheels will rub. I'm running +42 offset and there is a little bit of a rubbing problem. Haven't lowered yet, still waiting on struts and a camber kit, I know I'm gonna need it!
Can't remember how much the RS7's weighed, but I think they are around or just below the average weight for a 17" wheel...don't take my word for it though, just speculating...I don't remember them being that heavy...
Old Aug 24, 2006 | 12:07 PM
  #123
JDMish's Avatar
Originally Posted by Illusive
Here are mine: 17" Enkei RS7 in Anthracite with Kumho SPT's 205/40/17
what no led tails??
loving the look!
Old Aug 24, 2006 | 04:15 PM
  #124
Illusive's Avatar
no, craptacular Sony digicam won't take good pics, so I'm going out to get a new one today...better pics with new mods to come!
Old Aug 30, 2006 | 10:30 PM
  #125
008man's Avatar
Mpg
If you size up to a 17 inch rim, you will end up going to a wider tire (marginally) to fit the wider rim. That will increase your rolling resistance even if the overall diameter stays the same. But, more importantly, the 17 in rim will probably be heavier than the stock rim. This has a big effect on MPG, breaking acceleration and turnning. Why? Because this weight has to be spun up, spun down any time the vehicle changes speed. It takes energy to spin up and spin down. To change direction (try turnning a spinning bicycle wheel while holding it across the axle), the whhel will fight you (gyroscopic precession). Go to this link for a better explantion
http://www.tawvehicle.com/techwh.htm
You can gain an increase in performance by just going to lighter wheels. It is not a matter of carrying around the weight, it is a matter of accelerating and decelerating the wheels mass, and that takes a lot of energy. So you can chose style over light weight, and you will be hurting your cars perfomance all around!
Old Sep 2, 2006 | 02:20 PM
  #126
Fray Adjacent's Avatar
Senior Member
Keep in mind bigger wheels are heavier. Heavier means more power to make them turn.
I think what Sliver was talking about is the outside diameter, tire included. If the outside diameter is exactly the same with a bigger wheel, but lower profile tire, then everything stays the same.
Old Sep 6, 2006 | 06:36 AM
  #127
simons2k's Avatar
DEEP DISH option for the Fit...
Anyone running wheels with a lip. It seems like you can got with a wider lip in the rear based on "eyeballing" the rear fender. Staggered setup possibly?
PICS would help tremendously
Old Sep 6, 2006 | 05:33 PM
  #128
OBESE's Avatar
mine here
http://www.cardomain.com/ride/2437025
17" gestalt virouge chrome
Old Oct 5, 2006 | 07:05 PM
  #129
fits_all's Avatar
Volks fitment..?
hi..i would really appreciate if somebody helped me because i'd like to put 18's on my fit. Ive been planning this since forever so its not that I copied skunk2 with the volks but i like the GT-7 and there are some specs in here http://www.rayswheels.co.jp/cgi-bin/...?modelName=GT7 but I dont know anything so please help me and if they will fit..because even though skunk2 made it fit, i think it is because of the extended fender they did? Any comments are welcome
Old Oct 6, 2006 | 03:14 AM
  #130
MINI-Fit's Avatar
Try checking with-
http://c2auto.com/hondafit.html
For GT7 and fitment for the FIT and see if they will ship to you.
Volk GT-7 (2 piece bridgeless spoke) about $590+ each
http://www.vividracing.com/catalog/p...ducts_id/10787
18x7.5" or 18x8" 4x100 bolt pattern +45mm offset or +50mm offset
Gunmetal, Gold, Chrome, Silver finishes
In any case ask your vendor for help with fitment. Check if centering rings are needed.
Old Oct 6, 2006 | 12:31 PM
  #131
fits_all's Avatar
wow...pricey ones arent they.....Appreciate your help mini fit...
Old Oct 16, 2006 | 03:15 PM
  #132
fireman27c's Avatar
i put 17'' rims on the Fit on Sunday, and i've noticed a "bang" like the tire hitting the inside of the wheel well when i hit a pothole.. Is this common for 17's?
Old Oct 16, 2006 | 08:00 PM
  #133
simons2k's Avatar
Not if you have the right width & offset. How wide and what are the offsets for your wheels? They should be stamped/labeled somewhere on the wheel. If they're not visible from the outside surface, it might be stamped on the inside. You'll have to remove the wheel for this. They're might be a sticker inside the wheel indicating size/offset.
Old Dec 2, 2006 | 01:51 PM
  #134
edstroyer's Avatar
If your going bigger I guess Forged Steel wheels are recommended. I think Tirerack has 17" Mortegi Tracklite's that weight the same as the stock wheels (15 lbs).
Old Dec 4, 2006 | 05:17 AM
  #135
w1ndex's Avatar
Scratch that post, the wheels in my sig are my new wheels, hardly any scrubbing issues, and my mpg has improved.
Old Dec 6, 2006 | 10:48 AM
  #136
jtanoyo1's Avatar
17x7 replica Work Emotion CR wheels with 205/40/17 Nankang tires
Old Dec 8, 2006 | 07:48 AM
  #137
JDM_DOHC_SiR's Avatar
Looks Good!
Old Dec 8, 2006 | 02:44 PM
  #138
em2steve's Avatar
^Agreed. :]
Old Dec 8, 2006 | 05:18 PM
  #139
fits_all's Avatar
nice Jazz..is it dropped?
what holds me into gettin 17's is that ive seen many in pictures and they look pointing to the sky from the front and pretty nice decent looking in the back. Some sorta if like you were carrying a 300 pound music sistem
Old Dec 11, 2006 | 10:48 PM
  #140
sy11580's Avatar
who got White Shoes
hi everyone I'm planning to get white Rims for my MR Fit. I want to know do you guys feel very difficult to take care of the White Rims? Is it always need to clean it up to make it nice??? give me some suggestion plz!!!
