View Single Post
  #25 (permalink)
Old 12-06-2006, 05:59 PM
lanakano lanakano is offline
lanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to live
Quote:
Originally Posted by Appleton21
I did a search with Endless Japan and found out they make pads for both front and rear (four wheel disc)
wrote down the part numbers just need to find them and pass it on.
UPDATE:
Found it again on the Endless Site
Front Pad is EP288, and the have from the VN95 up to the CCX
Rear Pad (four wheel disc) is EP210
Not sure if the ES520 is the shoe for the rear drums.
MAybe someone could enlighten the difference between the EP and ES part number designations
I mean no disrespect to Appleton21 nor can I comment on the difference between the Endless EP and ES part number designations. However, I can report that the EP288 is not the right pad for the USDM Fit. I put these pads on and found them to be smaller in length, height and thickness to the OEM ones. I'm working with Endless now to find the correct pad. However, based on the OEM pad dimensions, Endless thinks it should be the EP280 pads.
I don't mean to high-jack this thread but can someone comment on how highperformance break pads will effect fuel efficiency?
