bleeding order for 2000 Accord
Old May 22, 2005 | 10:16 PM
noltian
Guest
Posts: n/a
I've heard honda accord 2000 with ABS has different bleeding order for
breaks. I've normally bled my toyota breaks right-rear, left-rear,
right-front, then left-front.
I bled my accord last night. It does not seem to have been done right.
I have a soft break. I've heard the order is different accord.
Does anybody know?
noltian
noltian's Profile: http://www.usenetcars.com/member.php?userid=1442
View this thread: http://www.usenetcars.com/showthread.php?t=243157
motsco_ _
Guest
Posts: n/a
Re: bleeding order for 2000 Accord
> Does anybody know?
The _brakes_ need to be done front-left, front-right, rear-right,
rear-left. Don't ram the pedal all the way to the floor, suck the old
fluid out of the reservoir and top up with fresh before starting. Don't
shake the can of fluid. Test before moving the vehicle. :-)
If you're in _______Australia ___________ Front right, front left,
rear-left, rear right (it's important to mention stuff like that :-(
'Curly'
jim beam
Guest
Posts: n/a
>> Does anybody know?
> 'Curly'
that's good advice, but if the master cylinder has got air in it, you
/should/ floor it. it's the only way to properly expel [compressed] air
that tends to reside in front of an incompletely travelled piston.
bottoming the piston forces the air outside the cylinder where it can
then be bled out, otherwise it tends to expand back into the cylinder on
release. this is where the advice to "bench bleed" frequently comes
from; inability to expel all the air without using full travel.
WaterWatcher
Guest
Posts: n/a
"jim beam" <nospam@example.net> wrote in message
news:xuqdndN8xt_J1BDfRVn-sw@speakeasy.net...
>>> Does anybody know?
>> 'Curly'
> bottoming the piston forces the air outside the cylinder where it can then
> release. this is where the advice to "bench bleed" frequently comes from;
Would a pressure bleeder get air out of the mc? I've got a Motive kit on
order and I'm going to bleed everything in sight when I get it ;-).
Ray
jim beam
Guest
Posts: n/a
>>>>Does anybody know?
>>>'Curly'
> Ray
they help one-person operation, but don't always guarantee a result.
example: an old mini which has bleed nipples at the /bottom/ of the rear
drum cylinders, not the top where the air is. short of an industrial
vacuum system, that vehicle is virtually impossible to bleed.
fortunately, honda engineers seem to get out of the classroom and pay
attention to practical reality so you should work out ok.
TeGGeR®
Guest
Posts: n/a
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in
news:428D485F.3070900@interbaun.com:
>> Does anybody know?
Bleed *longest runs* first.
1) passenger rear
2) driver rear
3) passenger front
4) driver front.
Some vehicles have identical braking systems for RHD and LHD cars,
differing only upstream of the proportioning valve. This allows the
manufacturer inexpensive compatibility with mounting the master cylinder on
either side of the car. If that's the case, then the bleed order is the
same for either drive, usually starting with the right-rear.
TeGGeR®
www.tegger.com/hondafaq/
motsco_ _
Guest
Posts: n/a
>>>Does anybody know?
> 1) passenger rear
> 2) driver rear
> 3) passenger front
> 4) driver front.
TeGGer, I'm sure the Helms (aka Bible) says it the way I've explained,
which is contrary to our old-school wisdom. :-)
'Curly'
TeGGeR®
Guest
Posts: n/a
news:428E00CA.8010909@interbaun.com:
>> 1) passenger rear
>> 2) driver rear
>> 3) passenger front
>> 4) driver front.
>> cylinder on either side of the car. If that's the case, then the
>> bleed order is the same for either drive, usually starting with the
>> right-rear.
I should have looked in mine first too (poor memory, y'know).
It seems (on page 19-10) that the Civic/Integra of my vintage has a
DIAGONALLY-split circuit. Correct bleed order is given as:
1) Right rear
2) Left front
3) Left rear
4) Right front
The sequence I originally gave is for a FRONT/REAR split, such as most
Toyotas.
Either way, you bleed the *longest run first*, as I originally stated.
I have no excuse for forgetting the diagonality of my brakes, as I bleed
them once every year.
TeGGeR®
What The!?
Jul 8, 2011 12:27 AM
h0pes
Feb 28, 2011 04:46 PM
TOOL
Nov 2, 2007 12:22 PM
Dick
Jul 21, 2005 07:31 PM
PMS
May 4, 2005 11:16 AM
