Acura CL Maplights w/Homelink install
Old Dec 7, 2006 | 06:56 PM
  #41
sillypuddy's Avatar
Someone that Posts too much
Originally Posted by jsmonet
with most setups all you do is train the homelink as usual (click the clicker while doing the weirdy dance on your head singing honda is great, etc etc), then you go to your garage door opener and have it accept your homelink as a trigger. break out your manual and look up how to add new remotes.
this, effectively, sets your opener to respond to one static code. homelink devices don't have the ability to mimic a rolling code so this is the workaround. with non-rolling-code setups you wouldn't have to program your opener, it would just respond thinking your homelink IS your old remote.
that's not true
the first programming step is to get the frequency
the second programming step is to setup rolling code.. as confirm by a phone call to homelink
-joe
Old Dec 7, 2006 | 08:37 PM
  #42
arsonall's Avatar
anyone know what kind of bulbs go in the lights and if you can change them to LEDs?
Old Dec 7, 2006 | 08:40 PM
  #43
sillypuddy's Avatar
it's just a regular peanut bulb
-joe
Old Dec 7, 2006 | 09:36 PM
  #44
eGadgetGeek's Avatar
Anybody have time to drive to Ohio and install mine for me? I was so excited to get the thing but can't find a half an hour of unitterrupted time to get it installed. Got a template for the cut out and everything.
Old Dec 22, 2006 | 10:24 AM
  #45
smeister's Avatar
Hey you guys think I can fit the maplight/homelink with the sunglass holder? I wonder if there is enough depths for the sunglass part to fit. TIA
Old Dec 22, 2006 | 10:38 AM
  #46
My wife's CR-V has the maplight with the sunglass holder and I was wondering the same thing. I had hers half way out to see if it would fit and got busted and had to put it back. Hers doesn't have the homelink though so I'd have to find one with the homelink.
Old Jan 24, 2007 | 10:26 AM
  #47
Tankist's Avatar
moth passed with no replys, and i wanted to ask the same question - will the unit with the sunglass holder fit depthwise?
for those who did the original mod (just the light and link) and cut the liner - do you think it might have enough depth or was it pretty tight as it is?
thanks
Old Jan 24, 2007 | 10:44 AM
  #48
sillypuddy's Avatar
it won't fit without some modification, such as moving it back towards the back, since the roof gets in the way :-P
-joe
Old Jan 24, 2007 | 11:52 AM
  #49
Tankist's Avatar
-joe
hmmm. somehow it looks like it is getting even shalower as you move back but from what you said it is the other way around. why? is there anything protruding from the roof in the "hump" area (the bulge closer to mirror mount)?
Old Jan 24, 2007 | 10:49 PM
  #50
sillypuddy's Avatar
I have all three styles of overhead consoles, tried them and they just don't fit.. so take my word for it :-)
if you want to do it, move back about 3-5 inches, but then it won't look the same as our installs
-joe
Old Jan 25, 2007 | 07:56 AM
  #51
smeister's Avatar
Thanks for the insight Joe!
Old Jun 15, 2007 | 06:28 PM
  #52
stephanpark's Avatar
DAng!
I just can't seem to get my hands on the CL with only the HomeLink. Plenty of ones with the sunglass bin, too bad it doesn't fit.
Here is an image that might help eye the depth needed if attempting +tray versions. Black bulge is pretty fat.
Old Jun 15, 2007 | 07:08 PM
  #53
Cost brand new!
Joe, I think I found what you were talking about here. I blanched at the price though...$311.22 USD before shipping,
Update: my mistake, according to mr-cappy the bulb and bracket are included in the #11 kit...so more like $199.26
Here are the parts roll call for future reference.
#11, LIGHT ASSY., FR. MAP ( CLEAR GRAY )
Honda SKU 34400-SS8-A02ZA
List Price $250.32
Delray Price $199.26
#12, BULB (T10 4CP)
Honda SKU 34401-S84-A012
List Price $2.93
Delray Price $2.34
(need two)
#13, BRACKET, MAP LAMP
Honda SKU 83206-SY8-A00
List Price $133.72
Delray Price $106.44
#15, SCREW-WASHER (5X14)
Honda SKU 93891-05014-07
List Price $0.53
Delray Price $0.42
(need two)
#11?
-joe
Last edited by stephanpark; Jul 20, 2007 at 02:42 AM. Reason: Updated info and formatting.
Old Jun 15, 2007 | 07:54 PM
  #54
smeister's Avatar
Thanks for the leg work. I've been trying to source this item also.
Old Jul 19, 2007 | 08:37 PM
  #55
mr-cappy's Avatar
Some questions on the wiring …
I went out to the salvage yards today but didn’t find the maplink … but did find one with the maplight missing so I cut off the connector … so at least I got the connector …
NOTE: during my research the Acura CL only offered the maplight with homelink WITHOUGHT sunglass holder in 98 and 99 … there was no Acura CL in 2000 and the 2001 model has the sunglass holder
I understand the positive to light and negative to ground … but to help clarify …
Wyy183 mentioned the red wire with white strip which is the center wire in the tree-pin connector … does this serve your memory also?
Spider2k mentioned one is constant 12v, one is ground and negative is switched from the door circuit
eGadgetGeek mentioned … “I tested my light this evening with a battery to make sure everything worked. The switched lights come on with the two outside pins powered. When you take the center pin to ground it lights the lights as long as they aren't already turned on. So, this would mean they are negative switched from the door circuit. Haven't pulled the dome light yet to see how it is wired”
So to help clarify everything … as shown in the pic …
The top pin goes to ground?
The bottom pin goes to the dome light red/white stripe wire?
The middle pin goes to the dome light green/brown stripe wire (to turn on lights when door is open)?
Old Jul 19, 2007 | 08:40 PM
  #56
mr-cappy's Avatar
Must find on eBay or salvage yard.
List Price $250.32
#12, BULB (T10 4CP)
List Price $2.93
Delray Price $2.34
List Price $133.72
List Price $0.53
Delray Price $0.42
#11 comes with 12, 14 and 15
Old Jul 20, 2007 | 12:28 AM
  #57
aznguyen316's Avatar
that is some clean, good looking installs by the both of you. oem look and feel.
Old Jul 20, 2007 | 01:41 AM
  #58
Thumbs up Thanks for update.
...OK, that's better. Still a stretch to far for me though. Thanks for the update.
Another guy was saying he had to get the bracket and bulb separately, must have been a salvage purchase then. My bad.
Last edited by stephanpark; Jul 20, 2007 at 02:36 AM. Reason: More appropriate reaction.
Old Jul 20, 2007 | 12:56 PM
  #59
mr-cappy's Avatar
The Bracket is seperate so would need #11 and #13
Old Jul 22, 2007 | 04:54 PM
  #60
sterVin's Avatar
anyone know of a website where I can get one of these? this + JDM center consul = awesome
