OIL, filter, maintance minder questions
Old Dec 14, 2006 | 07:48 AM
  #41
dan-bou's Avatar
oil change
my fisrt was at 12365 km and i have an appointement for nest week, the car write 5% and counter is at 24063 km.
highway use for 6 month.
Old Dec 15, 2006 | 12:41 AM
  #42
TotallyFit's Avatar
Um i do believe the major reason oil is changed is because the additives in the oil start to break down,and the oil doesn't do its job as well.And oil viscosity does make a fuel mileage different.0w20 will give you a tiny bit better gas mileage than,say,20w50.And if you use a heavier oil (like 20w50) you lose a little power.But that wouldn't be a problem for any of use because we should all be using 5w20 like we're suppost to
Old Dec 15, 2006 | 06:12 PM
  #43
mobortho's Avatar
My first change was at 6400 miles because we were leaving on a trip, but it was on track to say change at 8000 miles. The manual says change when the MM system warns you, or at least by the first year. I think 7500-8000 mile change is great. The 3-5k change is too often and wasteful. We've got good engines and good oils. Changing too often is wasting oil and time. The key is being regular and not missing it.
Old Dec 17, 2006 | 06:39 PM
  #44
startroops's Avatar
I was told by the dealership that the oil life depends on how you drive the car. So those people who drives on the highway alot, or they are just easy drivers, will have a longer oil life than those ppl who drive aggresively, or are constantly in bumper-to-bumper traffic.
This should explain why the oil life is different for everyone here.
Old Dec 25, 2006 | 08:12 AM
  #45
oohlala's Avatar
oil change
I just got my FIT recently and I know it's time for an oil change (approx. 6500km). However, the digital meter shows that the oil life still has 40%. Should I go with what the digital meter indicates? or should I just change the oil every 6000km???
Used to own an intrepid and the I just sticked to every 6000km.
Old Dec 25, 2006 | 08:20 AM
  #46
Tomh's Avatar
Senior Member
go with whatever you think is best, it's your car, some people will decide to go by the oil lilfe indicator, others may go more tradiotnal and stick to milage.
Old Jan 1, 2007 | 12:35 AM
  #47
benfal2001's Avatar
it's written 5w-20 in the user guide so you put 5w-20. point final.
Old Jan 1, 2007 | 12:38 AM
  #48
benfal2001's Avatar
You'll find the procedure in the user manual.
Old Jan 1, 2007 | 12:40 AM
  #49
benfal2001's Avatar
change when it's under 10%.
Old Jan 1, 2007 | 12:55 AM
  #50
coldstorage5's Avatar
Dude, its 5W-20. Its written all over the place. The first 2-3 oil changes use regular, then go to synthetic.
Old Jan 1, 2007 | 02:09 AM
  #51
Karyn's Avatar
Originally Posted by MtViewGuy188
My guess is that Honda will recommend SAE 5W-30 SJ-certified motor oil for the engines on the Honda Fit.
I'm betting Honda would recommend 5-20 like it says on the Fit's oil cap or maybe I'm being too stupid about this, but if they're recommending 5-30, I really wish they wouldn't put 5-20 on the cap because that just makes it really confusing for people like me.
Old Jan 1, 2007 | 02:43 AM
  #52
RCCOLA's Avatar
How does the maintance minder work?
I know it doesn't work off of mileage alone, but I would like to know how it actually works.
Does it have some sort of friction sensor?
Does it calculate the avg speed engine RPM and time?
Old Jan 1, 2007 | 02:49 AM
  #53
freaky fit's Avatar
aside from weights, but on the topic of oil, are hamp oil filters that much better? Hamp Oil Filter - JHPUSA.COM Serving JDM Since 1999
Old Jan 4, 2007 | 10:19 PM
  #54
Bounty Hunter's Avatar
BUMP...I'm curious about the technical side of this as well. Does it measure the oil viscosity constaintly?
Old Jan 5, 2007 | 08:14 AM
  #55
FitSport's Avatar
Computer monitors run time,speed,temp,idle time and using a program computes when you need to repl your oil/perform maint...
Old Jan 5, 2007 | 04:29 PM
  #56
manxman's Avatar
Not possible in a running engine!
Old Jan 11, 2007 | 05:42 PM
  #57
Garismatic's Avatar
Originally Posted by ndery
I got my Fit two month ago...
The dealer told me there is a viscosity probe in the oil telling the computer when to change the oil...at the right moment when the viscosity drops...This could explain a lot of things...
Wow. Your dealership was talking out of its bottom. Which dealer was it?
Old Jan 11, 2007 | 10:00 PM
  #58
spreadhead's Avatar
Obviously your dealer hasn't read an owners manual which says, "Based on the engine operating conditions and accumulated engine revolutions, the onboard computer in your vehicle calculates the remaining engine oil life and displays it as a percentage".
Old Jan 11, 2007 | 10:35 PM
  #59
03DSM-RSX's Avatar
Frequent FitFreak Poster
do not trust the oil life indicator. it does not do an "in-car oil a-nalysis" to determine actual life of oil left. just keep paying attention to mileage and record every time you change it.
Generally, regular Honda oil lasts up to 5k miles on "severe" usage, 10k on "normal". Synthetic oils can go longer change intervals, but i usually keep it on a 5k basis.
Old Jan 12, 2007 | 03:26 PM
  #60
dan-bou's Avatar
my first was 12300km, my second was at 24589km last month, i driving only on highway. Now i'm at 90% and 26758km. Oil change by dealership.
