A RADIO trick for the Fit...
Old Jan 9, 2007 | 10:52 PM
integradriv3r's Avatar
The other day while installing my tanabe exhaust i unplugged my battery (reasons unknown) and when i reconnected it i found out my radio needed a code to work again. I lost the paper that had the code so i went to the dealer. In order to get the code one must have the radio serial number which can be seen by.....
1) have key in and turned to second click (just have the radio on i guess)
2)make sure the radio is off
3)hold down the #1, #6, and then hit the Power button (volume knob) and a number should appear on the screen.
That would your radio's serial number and using that the people at the Honda dealer can use it to find what your code is to make the radio work properly again. Not sure if this is covered in the manual but i found it interesting and wanted to share it with you guys
Old Jan 9, 2007 | 11:35 PM
nttdemented's Avatar
Hmmm... place little piece of paper with security code in my wallet... CHECK!!
Thanks for the tip though, bookmarking this one in case I do lose the little card with the info.
Old Jan 10, 2007 | 09:27 AM
QuackXP's Avatar
If you have Honda Owners Link, there is a field on your profile for the radio code.
Old Jan 10, 2007 | 10:55 AM
Yonzor's Avatar
The code is also on a sticker in the car. PM me and I'll tell you where it is.
Old Jan 10, 2007 | 11:34 AM
kb8thekid's Avatar
dealer did explain this to me, and the code is on my owners manual
Old Jan 10, 2007 | 11:59 AM
Tankist's Avatar
thanks for the tip - printed out and attached to manual.
but what i cant understand is what is the point of this entire lockout feature if the way to unlock is known to everyone interested? i mean if it is designed to prevent theft it failed and the only thing it does is creating inconvinience to owners.
Old Jan 10, 2007 | 01:26 PM
Well it stops the stupid thieves.
Old Jan 22, 2007 | 09:21 AM
Garismatic's Avatar
The radio doesn't give you the unlock code. It gives you the radio serial number. The dealer is supposed to ask for proof of ownership of the vehicle before they take the serial number and use it to get a radio code.
Oh, and if the dealership put a radio code sticker on the car, then they've compromised your security by doing so. I wouldn't keep it on the car.
Old Jan 22, 2007 | 06:39 PM
spider2k's Avatar
this has worked on most honda radios for a while as well.
Old Jan 29, 2007 | 09:53 AM
bigmanbrainy's Avatar
Well, if we didnt put this on the internet it would be a lot less easily accesable...
Old Jan 29, 2007 | 10:02 AM
Fit of RAGE's Avatar
That's AWESOME!!!!
Old Feb 7, 2007 | 02:43 PM
mikeyfiend's Avatar
Is there really a big market for stolen stock honda radios?
Regardless, I'll keep this in mind when I get my FIT, for those rare times when I actually disconnect the battery.
Old Feb 16, 2007 | 12:51 PM
aallbbeerrtttttt's Avatar
i doubt the factory honda fit radio unit would be stolen much just because it's not a standard din size that would be able to be used in other vehicles
Old Feb 16, 2007 | 02:14 PM
spreadhead's Avatar
I wrote the radio code and key code somewhere under the hood if needed later.
crash001
Jun 28, 2024 07:54 AM
Mister Coffee
Feb 7, 2019 06:00 PM
Dexter38
Jan 10, 2018 09:55 AM
mikelowell915
Sep 1, 2012 08:35 PM
Lideusz09
Oct 9, 2009 05:41 PM
