Alignment Problem 95 Integra
Old Jun 10, 2005 | 06:34 PM
Nick
Guest
Posts: n/a
Hello everyone,
I had my tires changed a little over a year ago because the
inner side of the tire was worn out. When I had the tires changed I
also had an alignment done.
About a month ago I had a bubble forming on my front passenger
side of my tire and had this replaced. Seeing that the tire was less
than a year old, I opted not to replace this one. I went this
afternoon to change my oil and noticed that the same problem that I
had last year with the inner side of the tire was happening on the
tire that I did not replace. Now obviously this is again an alignment
problem, but my question is what is the likelihood that the problem
would be in the same place?
Also the car had 14" rims which came with the car and my
cousin who had the car before me replaced with 15" Acura GS-R alloy
rims. I'm also assuming that this shouldn't be a problem either. I'm
just wondering looking back at the alignment paper it shows my car
Make and Mode. Are the specifications shown on these sheets a range
for all Integras or is there a specific one for the GS-R model which
should have be used on my LS model?
Thanks in advance,
Nick
Here are the results from the alignment done last year if it helps:
Left Front
Actual Before Specified Range
Camber -0.7 -0.7 -1.2 .8
Caster 0.4 0.4 0.2 2.2
Toe -0.04 -0.09 -0.04 0.04
Right Front
Caster 0.2 0.2 0.2 2.2
Toe -0.02 -0.04 -0.04 0.04
Front
CrossCamber 0.0 -0.0
CrossCaster 0.2 0.2
TotalToe -0.05 -0.13 -0.08 0.08
Set Back 0 1/16°
Left Rear
Camber -0.5 -0.8 -2.0 0.0
Toe 0.05 -0.04 0.02 0.08
Right Rear
Camber -0.7 -0.8 -2.0 0.0
Toe 0.05 -0.02 0.02 0.08
Rear
TotalToe 0.10 -0.05 0.04 0.16
Thrust Angle -0 -0
jim beam
Guest
Posts: n/a
Re: Alignment Problem 95 Integra
Nick wrote:
> Hello everyone,
> Thanks in advance,
> Nick
> Left Front
> Right Front
> Front
> CrossCaster 0.2 0.2
> Set Back 0 1/16°
> Left Rear
> Right Rear
> Rear
> Thrust Angle -0 -0
1. not all alignment shops are any good. sure, they print a fancy
looking data sheet, but it's useless if the tech didn't place the
sensors properly.
2. wheels often have slight bends in them. a good shop will rotate
wheels so the sensors detect deviation & allow for it, but you're at the
mercy of a competent tech.
3. you can't adjust the camber or castor on an integra unless you buy
special adjustable wishbones. if stuff is bent, it needs to be bent
back. again, need a competent shop for that. the "adjustable" stuff is
just toe. toe angles are typically quoted as a range. could an
unscrupulous shop adjust to one end of the range knowing that it
accelerates wear?
personally, i like to have mine set to close to zero at the front as it
makes cornering slightly better, but it tends to wear front tires on the
inside edge.
bottom line, take it to a reputable shop with new equipment and keep
taking it back if you're not satisfied. eventually, they'll do it right
just so they stop having you waste their time.
Old Jun 13, 2005 | 03:26 PM
Nick
Guest
Posts: n/a
Thanks for the info. This shop that I had the alignment done at was
just an alignment shop and thinking that that's all they do (and being
in business for over 30 years), they should know their stuff. Now I'm
questioning of if I should even call them to have them the same
situation happen again in a year.
Do you or anybody else suggest that I take it to a Firestone
which has a lifetime alignment warranty, or should I go and take it to
an Acura dealer?
Thanks,
Nick
On Wed, 08 Jun 2005 17:54:43 -0700, jim beam <nospam@example.net>
wrote:
>Nick wrote:
>> Hello everyone,
>> Thanks in advance,
>> Nick
>> Left Front
>> Right Front
>> Front
>> CrossCaster 0.2 0.2
>> Set Back 0 1/16°
>> Left Rear
>> Right Rear
>> Rear
>> Thrust Angle -0 -0
>sensors properly.
>accelerates wear?
>inside edge.
Dave L
Guest
Posts: n/a
I have the Firestone lifetime alignment warranty and have gotten my money's
worth, BUT - you need to be wary.
1. They wanted to sell me new front brake rotors, since my brakes were
squeaking sometimes. Those same rotors were replaced less than a year
prior, by OEM rotors. I replaced the front pads myself - problem solved.
2. Told me I needed new brake fluid. Just had it changed by another shop
about a month earlier.
3. Wanted to change the oil - only had about 1k miles since the last oil
change. Declined and I checked it later that day. Clean and clear (Mobil
1)
4. Recommended some belts be replaced. Took it to my local shop for a 2nd
opinion. Ok, they needed replacement. Had them do it cheaper than
Firestone (don't remember the exact costs involved).
5. Said I needed to change my transmission fluid (for automatics). I drive
a 5-speed manual - no transmission fluid to replace!
Few more things, but you get the idea.
You're probably wondering why I was still taking my car there. I tell them
no need to do their "courtesy" check.
I'm not saying they are all bad, but just be careful. Also some techs will
do a better alignment than others, at the same location.
<Nick> wrote in message news:fdfoa1ds3a8ntl8p0aot11n8v8t6cpg05m@4ax.com...
> an Acura dealer?
> Thanks,
> Nick
> wrote:
>>Nick wrote:
>>> Hello everyone,
>>> Thanks in advance,
>>> Nick
>>> Left Front
>>> Right Front
>>> Front
>>> CrossCaster 0.2 0.2
>>> Set Back 0 1/16°
>>> Left Rear
>>> Right Rear
>>> Rear
>>> Thrust Angle -0 -0
>>sensors properly.
>>accelerates wear?
>>inside edge.
jim beam
Guest
Posts: n/a
Dave L wrote:
<snip>
no kidding! had my civic's alignment done last week. was told that i
had a problem - the rear was out and it couldn't be fixed. i checked
with the tech & got him to show me what the problem was. turns out,
he'd never done a honda before and didn't know where the compensator arm
adjusters were!!! and alignment shops want you to /pay/ for this kind
of "expertise"!!!
Redd
May 14, 2015 09:00 AM
mole177
Feb 12, 2011 11:40 PM
cmj912
13
Sep 1, 2010 12:17 AM
piperpiperpiper
May 9, 2009 03:36 PM
loud_tiger
Sep 8, 2008 06:34 AM
