2005 Accord 12 Volt Accessory Socket
Old Jun 10, 2005 | 06:34 PM
sam
Guest
Posts: n/a
The 2005 Accord has 2 12 volt accessory sockets but the power to both is
turned off when the ignition key is turned off. This means you can't
leave a cell phone plugged in overnight to recharge or use the accessory
power unless the key is on. Is there a fix for this? All my other cars
had the 12 volt power available all the time.
Seth
Guest
Posts: n/a
Re: 2005 Accord 12 Volt Accessory Socket
"sam" <justwantsmore@yahoo.com> wrote in message
news:11ai08bedkd7810@news.supernews.com...
Re-wire 1 or both of them to an always hot accessory plug on the fuse block.
E Meyer
Guest
Posts: n/a
On 6/9/05 9:55 PM, in article 11ai08bedkd7810@news.supernews.com, "sam"
Not sure about the '05, but on my '00 TL, there is an unused line to an
always hot fuse of the same rating in the connector going into the fuse
block. All that had to be done was move one wire to a different (and empty)
hole in the connector to make the cigarette lighter jack always hot.
The other power socket (in the console) shares a fuse with something that
needed to be switched (I don't remember off the top of my head what it was),
so there was no easy fix with it.
Yours is probably similar, but you will need the wiring diagram
(www.helminc.com) to know for sure.
Pucci
Apr 4, 2014 10:23 PM
juandelecruise
Sep 19, 2005 11:30 AM
Spoilaz via CarKB.com
Aug 9, 2005 10:30 PM
accord_owner@no.spam.com
Jul 15, 2005 10:30 PM
John W. Barron
May 4, 2005 04:44 PM
