How to remove driver seat?
Old Mar 2, 2007 | 07:48 AM
dan-bou's Avatar
Hi!
I want know if someone know how to do for remove the front driver seat without any problem of **SRS SYSTEM***?
I want do make some modification seat track for have a better position for drive.
Please i need your help on this case
Dan bou
Old Mar 2, 2007 | 06:40 PM
Deivioncrx's Avatar
If your woried about disconnecting the SRS wiring connectors, just disconnect the neg battery terminal, pull the SRS fuse and let the car sit for 10-15mins, then disconnect it, there shouldnt be a single thing to worry about. Then it should just be 4 bolts on the corners, you might have to slide the seat foward and backwards to get at the bolts.
skier2.0
Oct 27, 2019 05:03 PM
104
Jul 17, 2017 09:46 AM
Mike Weisberg
Nov 23, 2016 01:27 AM
parahands
Aug 18, 2014 08:48 AM
Marvino
Feb 8, 2011 07:50 PM
