Highest Tire Pressure for stock tires?
Old Mar 23, 2007 | 02:36 PM
acc's Avatar
acc
What's the highest tire pressure for stock tires one can run with the stock 14" Dunlops?
From the dealership it was prepped at 32 psi cold, i have raised it to 36psi and am going to track the improvement.
Anyone else have data.
such as and Increase of 1PSI equate to x % gain in fuel economy
Old Mar 23, 2007 | 03:02 PM
kps's Avatar
kps
Honda Fit Forums Moderator
From memory the maximum cold pressure is 44psi. It's written on the sidewall. I set 40psi front and 38psi rear, though admittedly I haven't checked recently.
Old Aug 10, 2007 | 11:44 PM
GeniuneFit's Avatar
I was thinking of riding around 38-40 psi. I don't mind a harsher ride. Has anybody seem a better mpg as a result of firmer tires?
Old Aug 14, 2007 | 01:03 AM
Gordio's Avatar
Your mileage will go up. The only worry you should be considering is don't go too high. I'ts not a matter of harsh ride, but if too high it might be likely to explode.
Old Aug 14, 2007 | 08:12 PM
GeniuneFit's Avatar
I filled up today and even though it is very hot outside and my tires might have been hot. I filled up to 36 psi. I figure when it is cooler I'll be riding at a good 33 or 34.
I've been getting 35-38 mpg avg since I got my car 7-13-07 on psi that was probably filled since it was done at the factory in Japan.
spaceballs
Nov 15, 2018 09:09 PM
bigcanoe
Nov 4, 2014 04:19 PM
vwli
36
Jul 31, 2014 04:01 PM
agios11
Aug 24, 2012 11:41 PM
gkitf16
Mar 18, 2011 12:55 PM
