camber kit questions, alignment front and rear questions and specs
Old May 3, 2007 | 07:51 PM
  #141
aznguyen316's Avatar
T1r springs or any lowering springs install question
Don't mean to alarm anyone, but I wanted to double check something. On lowering springs, the ones I am running (T1R).. are the rear springs the more narrow spiraled ones or the "fatter" ones? I've taken a look at pics, and I believe the rears are the more narrow ones but it's hard to tell on a few pics, I know all springs are different, but wanted to get an idea.
the "fat" ones I am referring to are the ones lying down. Front or rear?
And these:
look "fat" but are in the rear..
The reason I ask is b/c I think I may have installed backwards! lol
finally here's a set of my springs, just one side.. wanted to double check if they were rears.. I called A&J and they said they're rears, but I wanted to make sure!!
thanks
Old May 3, 2007 | 08:48 PM
  #142
WhatFreshHell's Avatar
...(deleted me making wrong guess so not to confuse people, heheh)
The springs SHOULD have markings that say which are front and which are rear.
Old May 3, 2007 | 09:13 PM
  #143
hmm nothing on the springs that say front or rear that I can distinguish. See that's why I'm a bit concerned. A&J confirmed to me the bottom pic IS rear and that the fronts are the fatter ones.. hmm
Old May 3, 2007 | 10:22 PM
  #144
spoonek4's Avatar
https://www.fitfreak.net/forums/aj-r...t=installation
Check out the pix on page2. I searched & read a couple threads before I installed my springs.
Old May 3, 2007 | 10:33 PM
  #145
thanks. I went ahead and installed the V2 rears w/o the spring seats to get it more lower than the V1's. Everything seems fine!!
Old May 3, 2007 | 10:38 PM
  #146
JamesBizzle's Avatar
these are the rears.
Old May 4, 2007 | 12:00 AM
  #147
that's what I was told. Thanks for that! I'm riding good now.
Old May 4, 2007 | 01:07 AM
  #148
sure man, any time.
Old May 6, 2007 | 09:41 AM
  #149
Killa_CiViC's Avatar
Alignment issues after drop?
Just wondering if anyone has had any kind of alignment issues after dropping your Fit?
I know it shouldn't be an issue at all with the rear axle, but even with the Mcpherson struts in the front, there's still usually some adjustability.
Old May 6, 2007 | 07:01 PM
  #150
spoonek4's Avatar
U meant for front suspension or rear suspension?
Old May 6, 2007 | 07:04 PM
  #151
Pretty sure there's not much alignment change in the rear, but I'm wondering how the front gets affected, yeah... like should I buy springs and camber bolts at the same time, or no?
Old May 6, 2007 | 07:08 PM
  #152
spoonek4's Avatar
I got my alignment done after the camber bolt was installed. Didn't do it just with the springs, without the bolts just to see the difference. The drop doesn't affect front camber much, not like the civic/integra.
IMHO u should get camber bolts installed w/ the springs. Unless u wanna see the difference and pay to do alignment twice.
Old May 6, 2007 | 07:13 PM
  #153
I do my own alignments ... but I was just wondering how much money I had to tell the wife I was going to spend for the parts to lower my car.
I know on my civic I probably spent $1000 total for the springs, shocks and front and rear adjustable upper control arms. Figured with McPherson strut suspension and solid axle rear end, I'd get out a good bit cheaper this time.
Old May 6, 2007 | 07:58 PM
  #154
spoonek4's Avatar
Hell yeah. Camber bolts are a whole lot cheaper than camber kit for civics. Too bad KYB don't make any shocks for Fit yet.
Old May 6, 2007 | 08:48 PM
  #155
Does anyone make aftermarket shocks for the Fit yet?
Old May 6, 2007 | 09:25 PM
  #156
spoonek4's Avatar
U can get JDM ones but needs to modify a little to make it fits. I don't think there's anything that fits USDM fit perfectly YET.
Old May 21, 2007 | 03:55 PM
  #157
Ro_Ja Boy's Avatar
Spring Install Thread?
Just curious if there is a spring install thread on here.
Any tricks or anything different about the Fit from other cars that I should know about before putting the springs on the Fit?
Thanks!
Ryan
Old May 21, 2007 | 03:58 PM
  #158
Search it up, there are a couple.
DIY spring install should find the threads.
Old May 21, 2007 | 04:05 PM
  #159
Ro_Ja Boy's Avatar
Tried without too much luck.
Old May 21, 2007 | 04:08 PM
  #160
fit4kris's Avatar
