Integra rear trailing arm bushing part number
Old Jul 24, 2005 | 09:25 PM
TeGGeR®
Guest
Posts: n/a
I'm posting this in case anyone Googles for this in the future. The part
number is
52385-SK7-N02
This is the big main bushing for the '90-'93 Integra. It is the same for
right or left and presses into the existing trailing arm. It cost me about
$75 Cdn each, versus over $300 for the whole trailing arm itself (which
contains the bushing).
That part itself does not come up on the dealer's software, but the NUMBER
is identified as "bushing, right rear". The number may also not come up in
on-line parts searches. This unit may have been produced as part of a
recall similar to that issued for contemporary Civics.
The "SK7" portion of the part number identifies the part as being specific
to the '90-'93 Integra. The '94-'97 Integra is "ST7", so this bushing may
not fit that model.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 31, 2005 | 10:30 AM
TomP
Guest
Posts: n/a
Re: Integra rear trailing arm bushing part number
Interesting, I was told the '90 Integra bushings were a bastard size all unto
themselves...
TeGGeR, have you actually test fit this bushing to a '90 Integra?
Cheers, Tom
> number is
> 52385-SK7-N02
> not fit that model.
> TeGGeR®
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Old Jul 31, 2005 | 11:32 AM
jim beam
Guest
Posts: n/a
> themselves...
not sure if there's anything different about the 90 specifically, but
for all others, i can confirm that they're not. i have civic and
integra bushings and they're identical sizes.
> Cheers, Tom
>>number is
>>52385-SK7-N02
>>not fit that model.
>>TeGGeR®
> Tp,
> -------- __o
Old Aug 6, 2005 | 10:34 AM
TomP
Guest
Posts: n/a
jim beam wrote:
> > themselves...
I have not actually measured the bushing diameter (or other dimensions for
that matter), of the trailing arms. But for sure the part numbers for the trailing
arm assemblies are different between '90 and '91. And, as I said before; I was
told the bushing diameters are the difference.
Anyone know this for sure?
> > Cheers, Tom
> >>number is
> >>52385-SK7-N02
> >>not fit that model.
> >>TeGGeR®
> > Tp,
> > -------- __o
Tp,
-------- __o
Old Aug 6, 2005 | 04:43 PM
jim beam
Guest
Posts: n/a
TomP wrote:
> jim beam wrote:
>>>themselves...
i doubt it's a size difference, but i /do/ know there is a configuration
difference between civic & integra, and between different years on
civic. the original old civics had "thin" member top & bottom, & a
largeish "padded gap" front & rear. later civics have much thicker
rubber top & bottom & much less of a gap front & rear. some integras
have bushings with metal inserts embedded in the gapped area padding.
i sent tegger some pics of some old style 89 civic & some 97 integra
bushings. we should collect this info & correlate it to part #'s
because this bushing is probably the most handling critical component on
the whole vehicle in any of these series civic & integra and it would be
good to know the options on what's available.
>>>Cheers, Tom
>>>>number is
>>>>52385-SK7-N02
>>>>not fit that model.
>>>>TeGGeR®
>>>Tp,
>>>-------- __o
> Tp,
> -------- __o
NORCAL SQ FIT
Jan 10, 2019 10:47 PM
vtcycle
Sep 13, 2014 12:43 PM
jimmyparky
Nov 5, 2008 09:06 PM
TeGGer®
May 4, 2005 04:44 PM
TeGGer®
May 4, 2005 11:16 AM
