Accord 2000 LX - Ignition key stuck, and then can't start the car. Pls help!
Old Jul 25, 2005 | 12:37 AM
success_ny@yahoo.com
Guest
Posts: n/a
I parked my car as I do every day, but then I could not get the key out
of ignition. It was just stuck in there. I turned the wheel back and
forth, tried to start the engine again - it would not start. After
several laborious attempts of turning the key back and forth, I got my
key out. I decided to start the engine again just to make sure it's OK
- it would not start anymore. I would just hear some clickings sounds,
my instrumental panel lit up as usual but the car would not start -
there was no sound of alternator running, just some clicking noise.
Tried several times - the same result.
Anyone knows what can be done to at least fix it temporarily so I can
drive to the Honda dealer?
Thanks!!!
Old Jul 25, 2005 | 09:35 PM
SoCalMike
Guest
Posts: n/a
Re: Accord 2000 LX - Ignition key stuck, and then can't start thecar. Pls help!
try a jumpstart to see if the batteries dead. did the ignition switch
recall cover the 2000? tho the key/cylinder thingie sounds like thats
the issue.
> Thanks!!!
TeGGeR®
Guest
Posts: n/a
Re: Accord 2000 LX - Ignition key stuck, and then can't start the car. Pls help!
success_ny@yahoo.com wrote in
news:1122264833.080895.130250@g47g2000cwa.googlegr oups.com:
> key out.
A repost of somebody else's similar incident:
"My friend purchased a (transmission) console switch from www.hparts.com .
The part is Honda# 35700-SM4-A91 hpart# 327830 and the price was $31.63
plus $5.62 S&H. She had a very experienced amateur install it. He looked
at the manual briefly then went out and installed it in under 20 minutes.
It should be pretty straight forward for anyone with just a little
experience, only slightly tricky part is to adjust it (if necessary) so
that the indicator lights match the shift lever position.
"Results: Since installing the switch January 2000, she has had absolutely
no problem with it. Previously the car would always experience the
syndrome until it had been warmed up for at least 20 minutes on even a
moderately cold day.
"To recap the symptoms:
"- Vehicle is 1990+ Accord with AT (others with AT may be affected
also)
- Problem is strongly linked to cold temperatures.
- Key cannot be removed after shifting into P
- Dash indicator light does not indicate "P" even though transmission
is positively in P
- Car cannot be shifted out of P after this has happened
- Problem solves itself when the "P" indicator lights which occurs
after a period of time related to the interior temperature of the car."
May be unrelated. Sounds like
1) ignition switch bad
2) poor/dirty/corroded power or ground connections at starter or battery
TeGGeR®
www.tegger.com/hondafaq/
cmchan
Sep 26, 2016 02:08 PM
clanbuster
May 1, 2015 10:34 PM
Cassini
Jan 6, 2013 10:57 AM
jeff_1986
Oct 30, 2011 06:26 PM
Chris Nicola
May 15, 2009 08:04 AM
