Review:vertex C-pillar Bar
Old May 17, 2007 | 07:57 PM
boyetssilverfit's Avatar
While im waiting for my Progress Rear Anti Sway Bar to arrived i decided to install my VERTEX RACING C-PILLAR BAR,i will not start a DIY on C-pillar bar because everybody knows how to install it,second most people in this forum installed their AJ RACING C-PILLAR BAR which i think is a good quality C-PILLAR BAR,my intention is to let other members know who dont have a C-PILLAR BAR that theres a VERTEX RACING C-PILLAR BAR that can compete in suspension category.
Old May 17, 2007 | 09:47 PM
Review:vertex C- Pillar Bar
First i inspect the product,looking for scrapes,bent,ununiform paint,deformity,i didnt find any.Second i weigh the product.its about 2 LBS.
Old May 17, 2007 | 09:52 PM
Old May 17, 2007 | 10:09 PM
Before i install it i removed the childs safetybelt,i dont need it and i want to offset the 2LBS weight that im adding to the car,the childs seatbelt is about 3lbs,so 3LBS MINUS 2 LBS = 1lb weight reduction even though i did some mods on the car,this is my call,if i have a kid that uses the belt i wont do it.
Old May 17, 2007 | 10:13 PM
Final task to complete the project,Bolt it on using 14 mm socket wrench.
Old May 17, 2007 | 10:55 PM
CONCLUSION:The VERTEX C-PILLAR BAR is a good quality bar,its made of alluminum,its easy to install,no fitment issues,the color is gunmetal,and the best part is its only $ 27 US DOLLARS!!!!!!, yes sir only TWENTY SEVEN DOLLARS !!!.Im sure J'S RACINGS C-PILLAR BAR weighs less than 2 LBS thats why its expensive,the BIG question is how many FIT FREAK MEMBERS are willing to pay $ 151.82 US DOLLAR plus shipping just to have a C-PILLAR BAR?I dont know!.I've been shopping around for C-PILLAR BAR for the past few weeks,yes sir about 2 weeks,I'm a FRUGAL shopper and i have patience and perseverance when it comes to MODS,this one is one of the result,i havent drive my FIT yet to test it coz i'm waiting for my PROGRESS REAR ANTI SWAY BAR,Once my rear anti swaybar arrives i will install it and drive my FIT to see how a VERTEX C-PILLAR BAR & PROGRESS REAR ANTI SWAY BAR COMBO performs on my car.So for you guys out there that want a C-PILLAR BAR,you can check it out at Vertex Racing .
Old May 17, 2007 | 11:33 PM
Hondady's Avatar
Nice write up man!
Old May 18, 2007 | 07:55 AM
smeister's Avatar
So how does the bar perform vs no bar?
Old May 18, 2007 | 09:19 AM
jits14's Avatar
You should totally check the difference of the vehicle with just the c-pillar bar. How can you tell how much just the bar helped out or the addition of the sway bar unless you test them one addition at a time? This is a review of the product, right?
Old May 18, 2007 | 10:52 AM
manxman's Avatar
I'm with these guys-
Please tell us what, if any, handling difference you feel with JUST the C-Pillar bar!
Thanks-
Dave
Old May 18, 2007 | 01:29 PM
Due to popular demand that i have to test drive just with the C-PILLAR BAR,i did the test drive today,my first test was a sign that i should only run 25 MPH on a curve close to our neighborhood,i did 35 MPH(I have a scangauge II)i could feel theres an IMPROVEMENT on handling,not much but noticeable,i believe that there are MODS that you do need to spend a lot of monet (for me anything more than $ 200 ) and C-PILLAR BAR is not one of them,for me its only a degree of satisfaction of how much my car can handle because i accepted the FACT that my FIT a'int no SPORTSCAR,I just want some improvement,paying just $ 27 dollars for this C-PILLAR BAR made my day, i cant COMPLAIN, just my $0.02 cents
Old May 18, 2007 | 01:51 PM
jits14's Avatar
Hey thanks for the response. I wouldn't expect you to get a large improvement, but I along with others have front/rear struts and no c-pillar. I have yet to buy one, but wanted to hear the difference it might make on the Fit. Although its a small difference, if you combine it with strut bars( huge difference) I bet it helps a lot more in combined ridgity.
Old May 18, 2007 | 04:24 PM
Your welcome,i would like to see first the result of my VERTEX C-PILLAR BAR AND PROGRESS REAR ANTI SWAY BAR COMBINATION before i do my next mods,the front and rear strut bar is not in my plan,for me bolting on the FRONT STRUT BAR BAR to the thin chassis is a waste of money if youre not racing which i'm not,the REAR STRUT BAR i think i wont need it coz of my PROGRESS REAR ANTI SWAY BAY.Each one us has a degree of satisfaction as far as MODS is concern,i think i will be satisfied on this combination.
Old May 18, 2007 | 05:49 PM
koolkevin1107's Avatar
very nice! but man i can't find the c-pillar bar on the website. can u send the direct link? Also,did u cut the plastic that goes around the seat belt holes or what?
Old May 18, 2007 | 06:25 PM
2hot6ft2's Avatar
I disagree on fitment
Ok, it fits. However the fitment leaves a little to be desired. I'm glad you did a write up on it but you left out pics after the install.
Maybe I'm just too picky. When you install the Vertex C-Pillar Bar the adjustments are almost at the very end of their adjustment as you can see below.
The bar sould be about 2 inches longer. I haven't seen how the others are when installed so this may be normal.
When mine arrived I took it out and screwed the adjusters out and thought this will never fit. It does fit but there aren't very many threads left once you adjust it enough to work.
The price was too good to pass up but keep in mind their return policy if you're going to say no fitment issues since some would consider this an issue.
"ALL SALES ARE FINAL from the date you receive the merchandise.
NO exchange or refund."
It's on eBay. Also there is no cutting involved there are caps that just pop off easily. You can see where they are.
My 2 cents.
Old May 18, 2007 | 07:45 PM
First of all there are three (3) issues that seperate between your installation and mine:1.i bought mine direct from VERTEX RACING and not on E-BAY.2.My installation is a C- PILLAR BAR not a REAR STRUT BAR.3.No Fitment Issue to me means no cutting,no drilling,no welding,no additional parts needed to install the product,however if you consider adjusting the product as a major issue in FITMENT then that is YOU,As i look in your STRUT BAR it looks 2 inches shorter on both side am i right?Mine too but not about 2 inches,I can say about 1/2 inch,for me its NO BIG DEAL,i just adjust it because the bar is adjustable,and after i adjust it i just tighten it with adjustable wrench. Heres some pictures and i will let the members decide if HALF INCH (1/2) SHORT on both side is considered a FITMENT ISSUE.
Old May 18, 2007 | 07:47 PM
Old May 18, 2007 | 07:51 PM
Old May 18, 2007 | 08:03 PM
im sure there are fit freak members here that want to have a C-PILLAR BAR but not willing to pay $ 151.82 US DOLLARS plus shipping,are they willing to pay $ 27 US DOLLARS plus shipping but the C-PILLAR BAR is 1/2 an inch short on both sides? i dont know the answer,the only thing i knew is im completely satisfied with my $ 27 us dollar c-pillar bar.
Old May 18, 2007 | 10:04 PM
Thanks KEV ,i order my VERTEX C-PILLAR BAR through the phone,their phone number is( 626) 810-1699,the guy i spoke to is calvin,nice people to deal with,shipping no hassle no problem.Regarding the plastic that goes around the seat belt or what we call it cover, i havent think whats the best idea to cover it,i will let you know and i will post pictures if something comes up on my brain.Right now my brain is not working because my PROGRESS REAR ANTI SWAY BAR just arrived.
