Fit Factory Radio Wiring Harness
Old May 25, 2007 | 12:57 PM
BamaBR549's Avatar
Custom wiring harness for 2007 Honda Fit. Used Metra 70-1722 to connect to the harness, and 71-1722 to connect to the radio. The 70-1722 isn't fully pinned out, so I had to buy FOUR of them, to get enough of the small pins and wires to fully pin it out. Pricey, but at least it's done right. The missing wires were for the security wire, speed sensor wire, etc, etc.
Soldered and heat shrink wrapped all the connections, spliced into the middle of the radio side wire, to create "pigtails" with the rest of the wire.
I only wish the factory radio provided an remote turn on lead. As such, I have to use the switched 12v ACC lead, I suppose, and the amps will be switched on with the ignition switch. If it proves to be a problem, I could use a toggle switch I suppose.
Has anyone else tackled the lack of a remote turn on lead yet, using the factory radio?
Old May 28, 2007 | 05:53 PM
bigmanbrainy's Avatar
woot! Would you look at that! Nicely done sir. I am getting the schoche wiring harness...I just hope that it has all te necisaries to hook up my dvd player.
Old Sep 23, 2007 | 11:44 AM
DagerOne's Avatar
^This. Seems it's been done, but I can't figure out how.
Old Oct 12, 2007 | 07:56 AM
MarkyMark's Avatar
I used the Rockford Fosgate 3Sixty.2
Old Nov 12, 2007 | 10:56 PM
BTetc's Avatar
The remote turn on lead is connector # B16 on the back of the radio. There is no wire in the wiring harness, but the pin is adjacent to the yellow wire on the 20 pin connector (there are six wires coming into that connector from the aux-in connector in the console).
thebluepotato
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
21
Mar 22, 2015 06:15 PM
Pjbrady
Mar 4, 2015 08:42 PM
bmwbob
Jan 26, 2013 11:54 PM
Crawly
Aug 20, 2007 05:13 PM
timster
Apr 7, 2007 10:40 AM
