Fit sport lip onto base front bumper
Old Jun 3, 2007 | 01:01 AM
sam21's Avatar
Hmmmmm....after further investigation I do believe that the base and sport Fits have two different but very identical bumpers.
College Hills Honda states that the base Fit bumper is
00104711-SLN-A71ZZFACE, FR. BUMPER (DOT)12007FIT
while the Sport Fit bumper is
00104711-SLN-A81ZZFACE, FR. BUMPER (DOT)12007FIT
I have no doubt that it can be installed.But I want to hear from other members,if there are any,who has done it.
I do believe the base fit doesnt have the little hole under the bumper for the tab from the sport lip to go into,but i may be wrong.
What can also help me alot also is,if anybody can take a picture of a sport bumper,without the lip of course.Just cause i wanna see the difference.
Old Jun 3, 2007 | 12:31 PM
JDMchris.com's Avatar
I run THIS
yes you can install it. The only thing you would need to do is either cut off that tab that goes through the bumper, or cut a hole in the bumper. But yes it fits.
Old Jun 3, 2007 | 05:36 PM
sam21's Avatar
Thanks man
do you know if there are holes on the underside of the base's bumper where i can use the bolts that are preset on the lip or do i have to drill them?
also do you know if the sport's sideskirt will fit?I understand the base one's dont have the holes for the clips?
Old Jun 3, 2007 | 08:12 PM
I run THIS
i believe the bumper does have the mounts, the sides do not however.
Old Jun 3, 2007 | 09:04 PM
sam21's Avatar
Thanks,yeah.I just took off that bracket that made the tab that was riveted on.Just did a mock up but all should be straightforward....just gotta get it dropped off for paint,cant wait!lol
do you know anything about the sideskirts?
Old Jun 3, 2007 | 09:11 PM
I run THIS
you can drill the oem spots on the side, and i think 3M double sided tape should hold the centers, so you dont have to make holes in the side.
Old Jun 4, 2007 | 10:45 PM
sam21's Avatar
Gettin back tommoro from paint,w00t!
All right migh as well,ask,lol....what about the rear lip?
Old Jun 23, 2007 | 02:37 AM
j5ive's Avatar
Just a thought...
Maybe the difference in p/n is because the sport bumpers already have the fog light cutouts while the base do not?
Anyways, good to know the sport lip can be mounted on a base without drilling the extra holes people say are visible when taking the lip off a Sport.
Old Apr 2, 2008 | 08:29 PM
michaelpotter's Avatar
Hi, just bought a used lip but the bolts are not included. Anyone know the specs, quantity and part numbers?
Old Apr 3, 2008 | 02:40 AM
Tofuman's Avatar
i just went to the hardware store and picked up self tapping screws and double sided tape. worked great.
Old Apr 3, 2008 | 03:21 AM
doctordoom's Avatar
Supervillain
if nobody here knows, and i'm not mistaken, you can go to the honda dealer's parts department and they can pull up a diagram of the front bumper area of the fit, and you guys can look at that and decide what parts you need to add the front lip.
Old Apr 3, 2008 | 11:52 AM
Tofuman's Avatar
^ i priced it, and it was going to be quite expensive for the OEM hardware. i went with the hardware store instead. ~ $10
ikutoisahobo
Apr 3, 2014 02:31 PM
UncleDaddy
Mar 26, 2013 11:04 AM
chechinsp
Nov 10, 2011 10:50 PM
Cl329
Oct 22, 2011 05:27 AM
jman245
Aug 13, 2008 01:46 AM
