STRUT BARS, rear, front, upper lower questions and answers
Old Jun 4, 2007 | 11:09 PM
  #141
nttdemented's Avatar
They feel fine to me. A little bouncy after large shifts on the road, (like 2 or 3 rebounds before the struts settle down). This should be fixed by harder and/or adjustable struts once they are available (HELLO KONI!!!!).
Other than that the feel is AWESOME!!! I love em.
Old Jun 9, 2007 | 05:23 AM
  #142
sosoqtpinoy's Avatar
Cusco Front Tower Strut Bar Rattles and Rubs!!! Help!
Just installed em today looks great and all... but just when i started to test run it in the streets it starts to rattle while im idled or when a take off slowly... so i looked inside and it rubs on top of engine....Does anyone have this issue? How did u fix it? Help me PLZ!!!
Old Jun 9, 2007 | 07:29 AM
  #143
SPON FIT's Avatar
i dont have it but i would suggest adding some washers under the bar
Old Jun 9, 2007 | 07:56 AM
  #144
p11wrg's Avatar
My Cusco tower bar has no problems. Maybe it is because yours is LHD? Cusco is designed for JDM models which are RHD.
Engines are the same so the only thing I can think of is RHD v LHD.
Al.
Old Jun 9, 2007 | 08:24 AM
  #145
JDM_DOHC_SiR's Avatar
Al.
USDM= Dive by wire... bigger t-body... less room around the tower bar..
JDM= Cable throttle cable t-body.... more room around the tower bar..
I wonder it it is possible for him to remove the black metal cover that is rubbing the tower bar.... if not possible removing a section with a dremel or bending it......
Old Jun 9, 2007 | 08:41 AM
  #146
p11wrg's Avatar
yes, that would explain it!
Al.
Old Jun 9, 2007 | 06:15 PM
  #147
Swimmer Boy's Avatar
I just bought the front strut bar today, ordered from Bulletproof, I was
assuming that the install of the bar is pretty easy, but I would appreciate
if someone could have a DIY of the install. I saw the DIY of another one
but he had already put the mounting plate on.
Old Jun 9, 2007 | 07:04 PM
  #148
manxman's Avatar
Originally Posted by ewdysar
Does anyone know what the c-pillar bar really does?
Eric
My personal opinion is that it makes a really good coat rack. I have serious trouble believing that it can possibly have any effect at all on handling. They are cheap, but I am not willing to waste the money to find out whether my opinion is right or wrong.
Old Jun 9, 2007 | 11:11 PM
  #149
awwwww..... Bump
Old Jun 10, 2007 | 11:44 PM
  #150
ezekielwhore's Avatar
i have zero problems with the cusco bar.
**edit**
i just went in my garage and popped the hood open. i have a pretty big gap between the bar and motor.
Old Jun 11, 2007 | 01:30 AM
  #151
**edit**
Do ya have any pics`?? to show how much clearance you have vice... his rubbing issue
Old Jun 11, 2007 | 02:08 AM
  #152
ill try to get some pics tmrw.
Old Jun 11, 2007 | 10:39 AM
  #153
will putting washers under the mounts affect the purpose of the strut ? will i lose anything? is there any other type of material some one would reccoment to put under the mounts?
Old Jun 11, 2007 | 02:57 PM
  #154
ewdysar's Avatar
What does the rear strut bar do?
The purpose of this thread is to analyze the practical functionality of the commercially available "rear strut bars" sold for Fits.
First I'll say that I don't think that they are really rear strut bars, because there are no rear struts on a Fit. The rear suspension is a torsion rear axle as discussed in other threads, with coil springs and shock absorbers. The shock absorbers do not appear to have any influence on locating the rear suspension, camber or toe-in.
The commercially available "rear strut bars" appear to mount only to the top mounting stud of the shock absorbers which are mounted in rubber bushings. Tying the tops of the two shock absorbers together should not have any effect on wheel attitude throughout the suspension travel and can't really add any rigidity to the monocoque structure of the body/frame. If the body flexes under hard cornering, this bar would just move the tops of the shock absorber around in relation to the body, and would not effect position of the tire or suspension.
If the rear suspension consoles were tied together directly, without the rubber mounts, some body rigidity could be gained, but I believe that the reinforcement would have to be more than just compression/tension between two points, cross bars in a vertical plane would be more effective.
The only way that I can think of where this type of bar mount might have an effect is if the shocks were mounted through monoballs, eliminating the give provided by the rubber mounts.
All of my suspension improvement experience comes from modifying Porsches (also monocoque, but rear wheel drive) for track and AX. There may be some aspects of the Honda engineering and shortcomings that I'm not aware of, so corrections to my theories are welcome and would be appreciated.
Thank you for your input.
Eric
Old Jun 12, 2007 | 10:43 AM
  #155
Yipee...i fixed my issue... just by uninstallin the mounts and reinstalling it by pushing the strut forward while tighting it... and loosening the bar in the middle and raising it up and pushing it forward while tighting it... so no more rubbing ...hopefullythe problem wont occur again...
Old Jun 12, 2007 | 01:18 PM
  #156
cusco lower arm bar and front strut bar
can i have both of these installed at the same time since i have a front strut installed already?
Old Jun 12, 2007 | 01:23 PM
  #157
JDMchris.com's Avatar
I run THIS
yes, but i believe the cusco lower arm bar is specific to the JDM fit.
Old Jun 12, 2007 | 01:42 PM
  #158
so it wont fit im guessing? does spoon have a lower arm bar? will i have any problems with the rear strut bar from cusco? Can u recommend any lower strut bars for the fit?
Old Jun 12, 2007 | 01:55 PM
  #159
aallbbeerrtttttt's Avatar
Old Jun 12, 2007 | 01:57 PM
  #160
any other suggestions?
