JDM Gauge Cluster into USDM Fit
Old May 18, 2007 | 07:34 PM
aallbbeerrtttttt's Avatar
After tearing apart my gauge cluster for the first time, to test it with a JDM unit, I found out that it will not work for the most part. Reason I say for the most part is because there are a couple things that work and a couple that don't.
Things that DO work
-Tachometer
-Speedometer
-Gear indicator (A/T)
-Mileage (reads kilometer)
Things that DON'T work
-Fuel level (stays at empty)
-Sport shift gear indicator (number read 6th gear)
-SRS (airbag light stays on)
-EPS (electronic power steering light stays on)
That's about it, just incase anyone in the future needed to know or was wondering
It looks cool and all, but sucks that it doesn't work
Old Jun 18, 2007 | 06:41 PM
micchung's Avatar
JDM to USDM
that sucks.. are you sure the dials were working in the first place?
i presume it wont work the other way from JDM to USDM either then..
i had just imported a pearl white fit from japan- i was thinking of getting some USDM clusters for my JDM car as mine currently showing KPH instead of MPH (as used in UK)
the other option i was thinking was to use just the speedometer
(*if anyone has a spare set USDM guage dials / clusters from an Automatic Transmission car - let me know and i would be happy to take off their hands)
Old Jun 22, 2007 | 02:44 PM
lsvtecdc4's Avatar
I know when I swapped in my JDM cluster into my Integra, I had to swap the green film for all dials/indicators to work properly. Also had to fill the tank and move the gas needle manually to full. After that, it worked fine.
Old Nov 26, 2007 | 07:24 AM
zechs's Avatar
hey man, if you're selling this im interested
micchung, do you think you can get me a price for that kind of gauge in japan? since you got your fit there?
Old Jan 21, 2008 | 10:19 PM
FITnessFREAK's Avatar
jdm gauges
Dear Customer
the JDM Fit cluster is need some modification install to USDM Jazz or Fit, and the car shop ask me will change the car plug and connect wire, and they said that is so easy, and then the Fit cluster all of the function is work, so that i think your local car shop can help you install this Fit cluster, thanks a lot
thanks for your support
partsstation
heres the link to the auction.
eBay Motors: Jdm Honda Fit Gauge Cluster GD1 GD2 GD3 Jazz L15a L13a (item 320209694239 end time Jan-29-08 11:55:48 PST)
i got this answer from the guy selling the jazz gauges on ebay. i love ebay!
Old Jan 21, 2008 | 10:47 PM
tonyrace_41's Avatar
Originally Posted by FITnessFREAK
Dear Customer
partsstation
does anyone did the modification of their gauges? It's much better if you can provide instructions on how to do it. Thank you.
Old Jan 21, 2008 | 10:58 PM
solbrothers's Avatar
so is it possible to swap the speedometer? to the one with kilos?
Old Jul 17, 2009 | 11:42 AM
andyd's Avatar
has anyone else done this?
Old Jul 17, 2009 | 11:57 AM
gd3vbp's Avatar
I don't think I've seen this done, but you're going to need to find a wiring diagram for the JDM and USDM clusters. Compare the wiring diagrams and then start rewiring it to work properly.
Old Sep 6, 2009 | 09:27 AM
Mapone's Avatar
Hi, I have a similar problem...
I want to install usmd gauge cluster to eumd Jazz, but wire connector is diferrent..
Does anyone have the wirelles diagram from usmd gauges?? Or where i have find it?
Thanks...
Old Mar 16, 2014 | 07:06 PM
Hannyah's Avatar
Hey,
Sorry to bring this old thread up. I have installed an A/T jdm cluster (the one with greyish background and orange lights), as I couldn't find an M/T one on yahoo auctions. I have the above problems and an extra one:
-Tachometer doesn't work
-Fuel Meter
-EPS
Did you ever found out how to fix it? If not, does anyone have any suggestions on how to fix it? Maybe the jdm sensors are different than the usdm sensors? I'm not worried about the EPS, as I can just pull off the light, but I do want the tachmeter and fuel to work.
Any suggestions would be appreciated!
GD3HONDAFIT
Mar 17, 2014 02:08 PM
Jamy
18
Feb 27, 2012 12:56 AM
6ick
Oct 3, 2011 01:07 PM
redrumm
Dec 17, 2008 02:19 PM
Hondasforlife
17
Apr 22, 2008 04:36 AM
