camber kit questions, alignment front and rear questions and specs
Old Jun 21, 2007 | 09:05 AM
  #181
Fit of RAGE's Avatar
Originally Posted by Yani
camber with proper toe will not kill your tires. i run 2* of neg camber on my car all the way around with proper toe and have 0 adverse wear problems (its not a fit)
Sorry, but BOTH camber and toe is a tire wearing angle. Just think about it. The only alignment angle that is NOT a tire wearing angle is caster.
Now, I've looked at my car today and noticed that the left rear tire also has LOTS of negative camber. enough to notice a big difference between the right rear. I'm taking it to the alignment shop just the get it checked out. if i's out,I'm taking it back to the dealer.
Old Jun 21, 2007 | 09:08 PM
  #182
phil_qc's Avatar
Hey, stock rear camber for the Fit is -1,5... so -2 is in spec
and normal... Hunter machine are precise but is the
rack 100% on level ground ? no! Every front traction
car run negative camber in the back, try looking at
the Yaris, same thing. -1 is visible with the eye, so
is -1,9. You cannot adjust the rear suspention at all
but front camber can be adjust with the strut bolt about
+- 0,5... front toe by the tye rods anf caster but unbolting
the 4 bolts of the subframe and shifting it (about +-0,7).
By the way, some of you are right, camber don't eat tires
that much, toe will. Oh, rear positive toe is normal on our
cars, it's for high speed stability and braking... and since
the back of the fit is so light, that normal amount of + toe
will not eat tires. Front should be set to 0 toe and 0 camber
(I like -0,5 with -2mm of toe) and caster to 3,5 without to
much cross caster because the Fit is short...
Hope that help, sorry for bad english,
Philippe
Old Jul 3, 2007 | 10:27 AM
  #183
YeeFit's Avatar
Anyone done an alignment after a drop? castor/camber kit needed?
Hey everyone,
I just called up a shop in town to bring my Fit in to get a wheel alignment done. The mech there said that I should have or might need a castor/camber kit installed..
I wasn't going to get an alignment, but after swapping out my stock wheels with my new ones, i noticed that the wear on the front tires was really bad on the insides and I don't want this to happen to my new wheels/tires.. and I've only have 7k on my Fit and about 5k since lowered.
I am lowered with Tein S-Tech springs 1.8/1.2
Old Jul 3, 2007 | 10:31 AM
  #184
fit4kris's Avatar
I have dropped the Fit on 2 different sets of springs and took it in to get aligned after. Never needed camber bolts. I believe they sell them but the results show within spec both times.
Kris
Old Jul 3, 2007 | 10:33 AM
  #185
piyoimut's Avatar
Everytime you drop, alignment is a must. regardless the wheels stay stock or changed.
Camber kit.. not a must but a "good to have"..
(because no matter how good the alignment is, extreme lowering will still wear tires un-even-ly)
Old Jul 3, 2007 | 11:00 AM
  #186
Illusive's Avatar
Hey YeeFit, who did you book your alignment with? I got an alignment a few weeks back, you will definitely need to get one done. My specs were all over the place after lowering. Highly suggest you go get one soon. The guys down at the Kal Tire near Chinook on 42nd are really good and specialize in lowered cars.
Old Jul 3, 2007 | 12:01 PM
  #187
Illusive's Avatar
Yeah they can adjust the camber a little bit, but nothing dramatically. No kit as of yet like Claymore said, so don't let them convince you there is and for you to install it...if they do, its a lie...
Old Sep 5, 2007 | 10:57 AM
  #188
smirff07's Avatar
so what im getting from this is...
ok so from reading the previous posts what i have gotten is that with the fit, installing lowering springs does not affect camber, front or rear as much as civics or integras. but i drive ALOT and do not want ot negatively affect tire wear at all!!!, so the only option i have as of sept, 07 is to get the allignment bolts from honda corp. am i right or wrong? what was you guys final readings after alignment with skunk2 springs? just wondering, cause thats what i have to install.
Old Sep 5, 2007 | 03:10 PM
  #189
tainogunslinger's Avatar
Interesting.
So it looks like I'm not going to need to adjust camber for my 1.5in drop and even if I wanted to, there isn't a "kit" available. lol
That's what I gleaned from this thread.. Basically, all I'll need is an alignment.
Last edited by tainogunslinger; Sep 5, 2007 at 04:51 PM. Reason: edited for content ;)
Old Sep 5, 2007 | 04:14 PM
  #190
daviddahlb's Avatar
Just the rear can't be adjusted, and it doesn't need to be.
The front should be adjusted, but you probably don't need the camber bolts, just crank the front camber where you need it.
Old Nov 18, 2007 | 02:43 PM
  #191
smirff07's Avatar
where can i buy camber bolts?
Old Nov 18, 2007 | 09:50 PM
  #192
MINI-Fit's Avatar
You can go to Honda Parts Dept-
Ask for the pinch bolts that allow front camber adjustment:
Honda Part number 90188-SCC-A00
Each about $4.77
You can use 1 or 2 each for right and for left. Maximum adjustment- use a total of four, otherwise 2 (one each side)
I used 2 for each side and got front camber -0.7 to -0.9 range vs -0.2 to -0.3 with stock bolts.
These bolts are size thread and length as stock but have slightly smaller diameter in the middle of the bolt which allows for a little adjustment.
After alignment using these bolts in the front-
Front camber -0.8 deg (right), -0.7 deg (left) [Stock setting + or - 1.0 degrees]
Front toe -0.11 (right), -0.12 (left) (Toe out) [Stock setting -0.12 to 0.12 degrees]
Caster 3.2 deg (right), 3.5 deg (left) [Stock setting 2.8 to 4.8 degrees]
Rear camber -1.8 deg (right), -1.7 deg (left) [Stock setting -0.5 to -2.5 degrees]
Rear toe 0.08 (right), 0.18 (left) (Toe in), [Stock setting 0.0 to 0.20 degrees]
Note- There were limits for adjustments on my Fit and this was the best the alignment shop could do.
(edit: The above part number is correct for USA Honda)
Or you can get a camber bolt kit for about $29 (one for each side)
Club RSX.com: SPC Front Camber Kit (Pair)
Old Nov 30, 2007 | 11:07 AM
  #193
hmgFIT's Avatar
Recently got my Fit aligned yesterday, i recieved a paper with OEM specs and current... I input information into a WORD document, if anyone needs OEM specs its in there.
screenshot:
download link:
http://members.cox.net/nengxiong1/ho...gnmentspec.doc
Old Dec 2, 2007 | 10:13 PM
  #194
hmgFIT's Avatar
Ingalls front/rear camber kit!
Has anyone bought the camber kit from Ingalls?
there's a ebay link: eBay Motors: INGALLS CAMBER KIT FRONT FOR 07-08 HONDA FIT (item 360000277069 end time Dec-03-07 08:29:59 PST)
and Ingalls is also listing the parts for front and rear on their site: Honda
Im excited, anyone else with information?
Old Dec 14, 2007 | 02:04 PM
  #195
sevenaprils's Avatar
Hey this is some good news to everyone out there in need of an alignment. If you have a local firestone car care shop, they are running a special on their lifetime alignment, 119 instead of the regular 140. You can come in for an alignment free of charge for the life of the car, so it'll pay for itself. I'm heading in later today for mine - hopefully they don't scuff up the wheels
The deal runs til dec. 31st '07.
Other info to note, if all the facilities are pretty much the same, then they can only work on cars that have less then a 2 inch drop, so my skunk2's are great, but I'm not sure about other manufacturers.
Anyway, good deal considering you'll never have to pay for another alignment so long as you own the car.
hope this helps others out!
Old Jan 8, 2008 | 05:43 PM
  #196
07fitsport's Avatar
so using lowered springs with anything prob significant such as 1.0 or more in front and rear that you need to just take to aligment shop and they will adjust a factory front suspenion bolt to fix alignment but the rear isnt affected or not affect enuff to worry????
Old Feb 25, 2008 | 06:51 PM
  #197
tattoopunk031's Avatar
I just had eibach sportline springs installed on my fit today and my toe is off, the guy at the shop showed me a print out of everything. He said its supposed to be between 0.00 degrees and 0.20 degrees. My left is 0.42 and my right is 0.31. He said there wasnt anything he could do but told me to research it online and see what i could find to fix it. He said maybe i should take it to a body shop and have the body modified a little bit. Any suggestions? I was thinking shims might fix it? The camber is totally fine tho. I didnt think these springs would lower the car THAT much but on my way home from the shop every little bump i hit, i heard the tire rubbing on the the car . Help!
Old Apr 7, 2008 | 02:29 AM
  #198
ericman20's Avatar
I might be lowering my car this week and I'm planning on getting front camber bolts; So what are the best specs to set my camber/caster/toe to for the best tire life, but yet keep a good performance.
I know I should keep Toe to 0 and Caster within specs, but how about camber?
Old Apr 7, 2008 | 02:46 AM
  #199
kkim's Avatar
I would go max camber that I could get out of those bolts. What is it... like 1 to 1.5 degrees, right?
Old Apr 7, 2008 | 05:07 AM
  #200
MINI-Fit's Avatar
I don't think you can set caster.
Toe settings you can always change. Stock toe settings can be:
Front -0.12 to +0.12 degrees or 1/8" toe in to 1/8" toe out.
Rear 0.00 to +0.20 degrees or zero toe to 3/16" toe in.
For aggresive street and performance driving try-
Front -0.12 degrees or 1/8" toe out
Rear zero toe to 0.08 degrees or zero to 1/16" toe in.
Front camber to maximum negative you can get- usually about -0.9 degrees vs -0.2 for stock.
More toe out in front helps turn in response but excessive toe out wears your front tires and makes handling twitchy.
More toe in for rear helps straight line stability.
These toe settings are still within stock range so I'd expect tire wear to be good. You can go more aggressive but with additional tire wear. If you do low mileage driving then it won't matter much but if you do long commutes then stick to stock alignment range for toe.
