what is the best way to drive to get the most mpg?
Old Jun 22, 2007 | 08:51 PM
charliehart1's Avatar
i drive a 5speed honda fit sport
i am fairly new to stick i had one back in the day but i never paid attention to mpg and now i am wondering what is the best way to drive
what rpm to shift at ect ect
Old Jun 22, 2007 | 11:48 PM
dank24's Avatar
I shift at 2k, and use the cruise control as often as possible. I am avg 35-39 mpg
Old Jun 23, 2007 | 11:45 AM
2 k really wow ... the only thing that sucks is that is a boring ass way to drive
Old Jun 23, 2007 | 05:45 PM
Misha's Avatar
Torque line is flat from 2500 - 3500 rpm , that would be optimal rpm range for normal / sensible driving.
Old Jun 25, 2007 | 12:36 PM
kps's Avatar
kps
Honda Fit Forums Moderator
Cruise in the highest possible gear; shift early (2.5K or less if conditions allow). Accelerating hard to get into high gear sooner is fine. Where traffic permits, accelerating quickly and then coasting in neutral (or declutched) is particularly efficient. Likewise roll downhill to pick up speed for the next uphill. The car uses no fuel while engine braking; use it to coast toward a stop or if you'd roll too fast downhill. Using the brakes is throwing energy away; do it as little as possible.
Old Jun 25, 2007 | 12:57 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
All of those above would be true if you drive like that for a month; the ECU will then learn thats how you drive.
My ECU knows that I drive with a slight heavy foot. If I drive like they explained above I cant break 100miles before 3/4 tank. If I shift at 3000-4200rpms with slight/sorta heavy foot then I get 33mpg city WITH a/c on.
If I drive like a beeeech, I get 29mpg. No more. Its happening right now. I didnt even break 200miles at half tank. Ughh!
Old Jun 25, 2007 | 09:25 PM
dank24's Avatar
I reach 230-240miles at half tank driving the way i do
Old Jun 25, 2007 | 09:51 PM
Posts in the NUUDE
I normally hit half with 210-220. Im modded, shift at 4500rpms (sometimes go to redline a few gears)
Im proud of my MPG. I would like to break the 35mpg mark.
Old Jun 27, 2007 | 01:41 AM
dank24's Avatar
that is good for taking the revs up
Old Jun 27, 2007 | 11:13 AM
FITrunner's Avatar
Downhill, with the wind, and in neutral.
Old Jun 27, 2007 | 12:37 PM
Gil554's Avatar
Depends where you drive as well. My wife is unable to drive less than 10 mph over the speed limit on the freeway. It kills the overall tank.
General stuff has been touched on. Here is my rundown:
1. Cruising in and shifting the lowest gear reasonable
2. Keeping speed (this can be fun too!)
3. Time lights to avoid overt braking
3. Neutral where possible and legal
4. Don't surge (unless its stop and go...you don't need your brakes on the freeway other than emergency situations. If you are using your brakes assess your following distance. Unless of course your in LA then proceed to tap your brakes every few seconds).
5. Don't speed (we drive a toaster...not an autobahn cruiser, high speeds are not good on the ole' mpg o'meter).
6. Don't autox/race (OK yes do it on a closed course...it's worth it!)
This is not comprehensive, and it repeats others as well. I use the above comments on myself on a daily basis to try and slow down, be safe, and save money. I drive like a little old man around town and autox on the weekends (helps get those redline urges out). Avg 37mpg combined city/hwy/autox
Gil
Old Jul 4, 2007 | 02:28 PM
MINI-Fit's Avatar
Keep your air filter clean
Keep your tire pressure up at the right level
Use a manual transmission for best results but if you have the automatic, let it shift automatically- don't assume you can control the gears for high mpg better.
Don't carry lots of heavy things in your car all the time- travel light
Don't let others drive the car if they don't observe the rules above.
Don't put on a roof rack and pile up stuff to increase wind drag.
Don't order extra wide and large aftermarket wheels and tires.
Old Jul 12, 2007 | 11:07 AM
cool_one556's Avatar
I have never gotten anything more than 160 miles or so at the half tank mark, on average I'm at about 130 half way.
pablolo
Feb 28, 2014 02:34 PM
pilot717200
Mar 17, 2011 05:21 PM
supaumar
Feb 3, 2009 08:22 AM
Hump-Free
Sep 28, 2008 10:21 PM
pcs0snq
May 10, 2008 01:04 AM
