Secondary O2 sensor
Old Aug 18, 2005 | 01:33 PM
Scott Rogers
Guest
Posts: n/a
Secondary O2 sensor
Hi!
Quick question:
Honda told me that my engine light is on because of a secondary O2 sensor
failure. I had this happen in my last civic too (this one is a 98 civic cx
hatchback) and it was about $600 to fix it! They said it was ok to leave it
for a while because it was only secondary.
Does this sound ok? Can I leave it? Can I get it fixed cheaper somewhere
else?
Thanks!
Scott
www.srpics.com
Old Aug 18, 2005 | 07:35 PM
someone
Guest
Posts: n/a
Re: Secondary O2 sensor
> Hi!
> Quick question:
$ 600.00 is way high (my 2000 Civic needs a O2 sensor and I've gotten
prices in the $325.00 range from Honda dealers) anyway I went to Auto
zone & they pulled the trouble code for free, mine is the heated part
of the O2 sensor, so my check engine light has been on for months now
however if the error showed the O2 sensor itself was having trouble I'd
replace it right away cause it may be sending a bogus signal to the
computer thus it may be trying to correct it by retarding the timing,
over fueling etc. See what the error code is and take the required action.
Rob Fruth - Houston, Tx
http://www.rfruth.net
spam@uce.gov
1981 Raleigh for errands & fun ____ __o
1997 Trek 2300 for real fun ! ____ _ \ | _)
2000 Civic hatchback (_)/ (_)
Old Aug 18, 2005 | 08:40 PM
TeGGeR®
Guest
Posts: n/a
Scott Rogers <scottNospaam@scottfromcanada.com> wrote in
news:Xns96B689179F3scottNospaamscottfro@216.196.97 .142:
> Hi!
> Quick question:
*Honda* told you nothing. A franchised dealer told you this.
> sensor failure. I had this happen in my last civic too (this one is a
> 98 civic cx hatchback) and it was about $600 to fix it! They said it
> was ok to leave it for a while because it was only secondary.
> somewhere else?
Unless you need to pass an emissions test, you can leave it alone so long
as the MIL will stay turned off, or you don't mind driving around with a
yellow light on your dash. The downstream O2 is there solely to keep an eye
on catalytic converter efficiency. It has no other function.
If you don't mind variable quality and possible short lifespan, you can get
a cheap Bosch or Niehoff or other generic sensor for much less than OEM.
TeGGeR®
www.tegger.com/hondafaq/
Old Aug 19, 2005 | 12:30 AM
SoCalMike
Guest
Posts: n/a
Scott Rogers wrote:
> Hi!
> Quick question:
the part, OEM is more than the primary one in the manifold. the manifold
one was $220 at my local dealer. the bottom one is below the catalyst.
> else?
$600 is wayyy too high by half, if ya do it yerself
> Thanks!
> Scott
> www.srpics.com
Old Aug 19, 2005 | 02:39 AM
Steve H
Guest
Posts: n/a
2nd O2 will not effect timing; it's job is to report how well the cat
converter is doing it's job.
Stephen W. Hansen
ASE Certified Master Automobile Technician
ASE Undercar Specialist
"someone" <rob@nospam.com> wrote in message
news:T08Ne.2834$r54.685@newssvr19.news.prodigy.com ...
>> Hi!
>> Quick question:
> prices in the $325.00 range from Honda dealers) anyway I went to Auto zone
> & they pulled the trouble code for free, mine is the heated part of the
> O2 sensor, so my check engine light has been on for months now however if
> the error showed the O2 sensor itself was having trouble I'd replace it
> right away cause it may be sending a bogus signal to the computer thus it
> may be trying to correct it by retarding the timing, over fueling etc.
> spam@uce.gov
Old Aug 19, 2005 | 05:30 PM
Scott Rogers
Guest
Posts: n/a
This is canadian dollars, so $450 US (ish). I dont think I can do this
myself. On my last civic they har to use a torch to heat it up to get it
off. But I think I can get someone to do it. A former dealership
mechanic.
Thanks guys
Scott
SoCalMike <mikein562athotmail@hotmail.com> wrote in
news:sbmdnXclR6XDyJjeRVn-vw@comcast.com:
> Scott Rogers wrote:
>> Hi!
> manifold one was $220 at my local dealer. the bottom one is below the
> catalyst.
Old Aug 19, 2005 | 06:48 PM
SoCalMike
Guest
Posts: n/a
> mechanic.
> Thanks guys
> Scott
$450 isnt TOO bad, if the sensor itself is $350ish. its right down there
in the open, and not rocket science. in fact, its easier than replacing
a spark plug in some cars :)
but someone else posted its not crucial, so its probably not a big
issue. if aftermarket is a LOT cheaper, id consider that. id probably
stick with OEM on the primary sensor, though.
rwjd
Apr 12, 2024 11:54 AM
apexanimal
Feb 22, 2016 11:51 AM
Gary Dyrkacz
Jul 10, 2013 09:11 AM
leonine
Nov 9, 2006 11:23 AM
someone
Aug 16, 2005 12:32 AM
