Anyone into stretched tires and wide wheels?
Old Jul 13, 2007 | 12:03 AM
scott's Avatar
warranty safe?
Actually, most companies that sell aftermarket parts that would affect your warranty,should be able to tell you if any given part would void your warranty.
Example:I purchased a performance program chip, and the company documented the product to be warranty acceptable.
Ask and you will see. If they can't tell you then keep lookin.
If you have, or are thinkin about puttin on stretched tires I hope you travel alone, and not in my neighborhood!
Do a little research on stretched tires after all that was the subject right?
Look up all the info you want, the only endorsements you'll find on this are people who have been irresponsable enough to do it.
There are NO tire manufacturers, or tire specialists that will approve it.
There IS a reason why.
Here's just a small sample of sites.
Wheel Sizes
Negative effects of stretched tires? - Bimmerforums - The Ultimate BMW Forum
VWvortex Forums: Tire Stretching - Discussion
Old Jul 13, 2007 | 12:55 AM
Whitehybrid's Avatar
again, any links to your hundreds of aftermarket, warranty safe parts? i didn't see any, and oem honda offered parts don't count, only 3rd party...what about the ls1 cars [vettes,goats,camaros,etc] on the street with d/r's? if it rains, they better not be in your neighborhood! and hopefully they are driving alone! i'll be more then happy to post pics of me, driving through your neighborhood with a car full of people, and 195s stretched over 8 inch wheels...provided you lend the address...i would put 20 bucks against it that YOU couldn't tell i was on stretched tires...funny thing too, if you call Axis, they'll reccommend a 195/50/15 for their 15x8 inch products on certain vehicles...better turn them in!! oh noes!!
also, the car company decides what they deem to void the warranty...whether or not the "aftermarket" company says its safe...they don't have the final say, the car company and automotive department of the dealership does...you could get a tech on a bad day and he would spit on your chip and tell you that its the reason your plugs fouled out and you threw codes, and they won't cover the repairs...
/yourself
Old Jul 13, 2007 | 01:40 AM
Sugarphreak's Avatar
Push My Button
As a BIG disclaimer I might just be talking out my a$$, but this is how I understood the warranty worked in situations like this;
I was under the impression they have to honour the warranty if the defect cannot be attributed to aftermarket changes. For instance if you put aftermarket tires that (lets say for example) are much much heavier than your stock tires and your studs break off (again, this is just a super highly unlikley senario for example only) they probably won't cover it under warranty. However in contrast, if your fuel pump dies there is no possible link between the tires and that component so they have to honour the warrenty. Even if there is a closly linked aftermarket part they have to prove reasonably the modification did the damage or it can be contested in court.
I have heard here in Canada you totally void your warranty if you even touch the Cat converter because of super strict gov regulations on it. Technically the regulations are so tight you can get into trouble even if you replace it with an aftermarket one if you can't prove the old one was damaged and in need of replacement (within a certain number of years on a brand new car). lol, I say technically cause I have never heard anybody getting called on it yet
Old Jul 13, 2007 | 02:33 AM
Mattec's Avatar
There is a legal clause about aftermarket parts that if not directly linked to the problem may still allow you to keep your factory warranty.
However....If the dealership wants to play hard ball then...well you are screwed. Don't think that every dealership will honor this...if you do, you are a fool. It will basically be the mercy of the dealership if they decide to keep your warranty or not. Why you might ask?
Well... lets say you have a $500 repair that needs to be done, on the engine (regardless of what part it is) and you happen to have aftermarket parts on your engine. If the dealership wanted to, they could say sorry we are not covering it, your warranty is voided. Even if the aftermarket part did not cause the problem.
Then what are you going to do, if the dealership flat out says NO to your face? Are you going to try and sue them? LOL!!!
The court battle would be tied up for so long and just lawyer fees alone would cost more than the $500 repair. In fact they could fight it longer than you could in court because...well they have more money. lol!!
But even if you stuck with it through the end and won your case in court. Your lawyer fees and time spent taking off work to appear in court would cost you far more than the original $500 repair.
So what it boils down to is...you are stuck with $500 repair regardless if the aftermarket part caused the problem or not. If the dealer so wishes.
I'm not saying don't mod your car, or that I'm against it. Just don't go crying when the dealership says "Nope...sorry"
Old Jul 13, 2007 | 03:27 AM
alabastersilverjazz's Avatar
EURO style for Jazz...hmm worth a try
as jtanoyo1 said..
I think strecthed tyres are fine. Had 225 on 10" wheels and it worked just fine. Just avoid potholes
BTW jtanoyo1..is that the most recent pic of your jazz? I thought you had 17" SSR with Porsche BBK. Am I talking abt the same Jazz?
Old Jul 13, 2007 | 09:35 AM
Push My Button
Yeah that is true, dealers can be your best friend or your worst enemy.
I know here (again, in Canada) If the problem was under 5000$ you could just run it through small claims court, doesn't cost too much to do that here. Like 100$ for the application, you can serve them yourself and you basically represent yourself in court. I have gone through the process once a few years back with a greedy landlord. If you win the losing party has to pay for any extra costs you incur, the application and any lawyers fees that you can prove to the court are directly related. The biggest thing is finding a precedent case similar to yours, but I am sure there must be a good number of disputes regarding vehical warranties.
In any case if you can find a solid precedent case (this should be true in the US too) they would probably just settle instead of incurring more costs knowing they will be ruled against.
I am not sure, does the losing party have to pay for all of the winning parties court costs in the US too?
Old Jul 19, 2007 | 12:21 PM
jtanoyo1's Avatar
as jtanoyo1 said..
I had 17" R2 forged wheels on porsche bbk. It's gone now. Now I got 15" Advan RG2 on Rotora bbk...
Oh yeah, GUYS IF YOU WANNA TALK ABOUT WARRANTIES AND OTHER CRAP, PLEASE MAKE YOUR OWN THREAD.....
THIS IS FOR STRETCHED TIRES on WIDE WHEELS THREAD!!!!
Old Jul 19, 2007 | 12:23 PM
jtanoyo1's Avatar
Originally Posted by Whitehybrid
you know from personal experience? i've yet to run into anybody that has had any problems with stretched tires...hell i'm doing a test fitment with 15x8 OGs with 195s this weekend since the wheels i'm ordering are about the same specs...half the times shops won't do it not because its unsafe, they just don't know how, or don't want to damage the wheel...
i just love the ignorance of some people..."oh if its not recommended from the factory it is dangerous and will never work correctly"...go tell that to the vip scene...you'd have to be pushing the car beyond it limits to cause danger with a stretched tire, even then, you would be pushing the limits with a stock width tire and get similar results...its a double edged sword...theres a difference as well for a properly stretched road safe tire, and one that was heated with a blow torch to be trailered to shows...you can't catagorize them all...
THANK YOU!!!!
Old Jul 23, 2007 | 07:01 PM
CarDemon's Avatar
Senior Member
OMFG! It's a sexy look I wouldn't have the balls to do.
I'll be awaiting the pics in another post of a member about to do it.
Team that up with some nice aggressive rims or even deep dish, lowered car and the bulldog stance and growl is complete. I've seen many German car owner s do that and I bow down to them.
Can't wait!
Old Jul 23, 2007 | 08:17 PM
Can't wait!
just did it...only tested the fronts...i'm almost too low on my t1r's...no spacers and fenders need to be rolled...its do-able, but i wouldn't daily it...oh and no rub on the inside of the wheel well...
i'm still debating...
Old Jul 23, 2007 | 10:20 PM
redrumm's Avatar
work euroline dh probably 18 with a DIY camber correction and a sick ass stance.
saw this on the DIY camber. to run a big rim and stretched tire combo, it would only look good with camber IMO
Old Jul 23, 2007 | 10:29 PM
  #32
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Although its not a Fit, me and my friend are doing this to his RSX-S. Just waiting on tires.
I cant wait to put them on the car.
He wanted something different on his RSX. So we decided to steer away from JDM and go EDM. Wide wheels, stretched tires. May be a first on the RSX. I tell you no one on ClubRSX likes it. That site is full of assholes tho.
Wheels were for his friends Supra. 18x9 in the front, 18x10 in the rears.
SICK!!! Q45 headlight conversion.... Looks mean!
Old Jul 23, 2007 | 10:44 PM
  #33
redrumm's Avatar
i think sportmax rims would look good but there 15x7 and 8 +15 with the big lip
Old Jul 23, 2007 | 11:03 PM
  #34
SPON FIT's Avatar
Post
post some pics up of the rsx when you guys get the tires on.im thinking it will look pretty sick
Old Nov 30, 2009 | 01:36 AM
  #35
drock46's Avatar
I wanna see more of this! Very interested in a Hellaflush Fit.
Old Nov 30, 2009 | 04:31 AM
  #36
90 DGRZ's Avatar
yea, stretched tyres always look good. it's not as dangerous as people think. 195 on an 8 will look great, esp with a smaller sidewall.
btw, isn't that rsx on clubrsx? thought my friend showed me his build thread with ridiculous wheel fitment.
235/40 on an 11. drifted on'em all day long til i sold the wheels. never came off the bead even with all the side to side force. now i run 225/40 on 10.5's.
Old Nov 30, 2009 | 09:17 AM
  #37
drock46's Avatar
very nice.
that fitment on that 240 is sick man, also i see a fellow rc drifter very nice as well.
Old Nov 30, 2009 | 10:54 AM
  #38
Texas Coyote's Avatar
I was doing his on VW Beetles in the early 70s but not to the extent that is shown in the pictures posted here and with higher aspect ratio tires.... This is a styling fad that really is more likely to create problems that will prove to be expensive to correct and offers no beneficial performance gains.... This will be something you will look back on in retrospect and wonder, what in the hell was I thinking.
Old Nov 30, 2009 | 11:56 AM
  #39
drock46's Avatar
i guess your half right, but when you think about it most people look at us like were crazy for the money we throw into cars they wouldn't bother look twice at, so i say ,if they're gonna look at us crazy anyway, why not give them a reason to?
Old Nov 30, 2009 | 12:00 PM
  #40
drock46's Avatar
anyone have any examples of some offsets and wheel specs people have been able to make fit on the fit and what suspension and tire size helps too.
for example anyone fit any sportmax wheels? 002's +0, or 501's +15, etc.
