Mobil 1 Oil Filter Part Number Enquiry
Old Aug 24, 2005 | 11:34 PM
Scott
Guest
Posts: n/a
I'm wondering if anyone here happens to know which Mobil 1 Oil Filter
would apply to a 2005 Honda CR-V SE?
I used Mobil 1 High-Efficiency Oil Filters on my '89 and '97 Honda
Civics for many years without a problem, but for some odd reason, I
cannot seem to locate the specific filter part number for the '05 CR-V.
I used number M1-104 on the Civics and I'm thinking that number M1-110
should work on the CR-V, but I haven't been able to confirm or
cross-referenece this either on-line or at the automotive parts store.
Any input and insight on this little dilemma would be very much
appreciated. Thank you very much in advance for your time and
consideration!
--SCOTT
Old Aug 25, 2005 | 03:30 PM
knowgo@gmail.com
Guest
Posts: n/a
Re: Mobil 1 Oil Filter Part Number Enquiry
the new "thimble" sized Honda filters are very good the part # is
15400-PLM-A01.
I know the Mobil 1's are very good, too but if you can't find a cross
with the Mobil...I woudn't fret as the same tiny filter is on all the
new Honda's, even the bigger V6's.
be sure to make sure you have removed the gasket from the block, if it
sticks. They had a problem with sticking to the older CRV's.
Old Aug 26, 2005 | 11:41 PM
Scott
Guest
Posts: n/a
If there are any other interested CR-V owners around, I called the
Mobil Oil Corporation at 1-800-ASK-MOBIL (that's 1-800-275-66245) and
they indicated having only one Mobil 1 High Efficiency Oil Filter
available for the 2005 CR-V's four-cylinder, 2.4-Litre iVTEC engine:
it's part number M1-110.
Have A Great Day!
Old Aug 27, 2005 | 10:31 AM
D.D. Palmer
Guest
Posts: n/a
Is there REALLY a difference in the oil filters (Mobil 1 vs Honda OEM)? If
so, I might consider it.
"Scott" <ARCADIA@webtv.net> wrote in message
news:13608-430FCCB8-88@storefull-3214.bay.webtv.net...
> Have A Great Day!
Old Aug 27, 2005 | 01:32 PM
SoCalMike
Guest
Posts: n/a
i dont see anything bout the mobil1 *filter* that makes it worth $10.
stick with OEM and mobil1 oil.
Old Aug 27, 2005 | 04:43 PM
D.D. Palmer
Guest
Posts: n/a
Yeah, that sounds about right. With 10,000 factory-recommended oil changes,
Mobil 1 gives me a little more comfidence to actually go that long.
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:wLSdnUWed9XaBY3eRVn-1A@comcast.com...
>> If so, I might consider it.
Old Mar 9, 2015 | 11:07 AM
GC617289's Avatar
M1 Extended Performance Filters
Mobil introduced the M1 EP filter because they introduced EP oil. As far as I know, they are the only filters guaranteed to perform for 15,000 miles.
The Honda filters are 3,000 mile filters.
If you plan to change your M1 oil every 10,000 miles, as I do, you have limited options: M1-110 or M1-104, Bosch L3323, and Purolator PSL14610.
Old Mar 27, 2015 | 06:02 PM
GC617289's Avatar
More 10,000 MIle Filters
In fairness to the competition, I must also add the FRAM XG7317 and Pennzoil HPZ-37 to my list.
BenjaminFit
Mar 23, 2011 12:49 PM
honda2112
Sep 22, 2010 11:17 AM
helphelp911
16
May 31, 2010 09:12 AM
Lek
Jul 4, 2009 03:34 AM
coopula
May 29, 2006 12:01 PM
