1986 Accord - fuel pump relay problem - HELP!
Old Aug 27, 2005 | 06:55 PM
saltydad58
Guest
Posts: n/a
Thought my fuel pump went out - replaced it, but still won't run. Replaced
relay next, and it ran for around 50 miles and quit. Now won't start.
No electricity to fuel pump - blue wire from ignition coil dead. #1 fuse
going to relay is hot. I'm stumped. Any help would be greatly appreciated
- I need a car running by Monday morning!
TeGGeR®
Guest
Posts: n/a
Re: 1986 Accord - fuel pump relay problem - HELP!
"saltydad58" <saltydad1@nospam.cox.net> wrote in
news:0cebcaad51790547f7cc41d0b2d2ebac@localhost.ta lkaboutautos.com:
> Replaced relay next, and it ran for around 50 miles and quit. Now
> won't start. No electricity to fuel pump - blue wire from ignition
> coil dead. #1 fuse going to relay is hot. I'm stumped. Any help would
> be greatly appreciated - I need a car running by Monday morning!
Ignition switch?
http://www.tegger.com/hondafaq/start...ignitionswitch
TeGGeR®
Old Aug 27, 2005 | 07:30 PM
'Curly Q. Links'
Guest
Posts: n/a
When a fuse gets hot, it sometimes means there's a corroded or loose
connection in your fuse box. Once the fuse gets too hot, it will blow,
since it's easier to blow a hot fuse. Tegger's FAQ also shows a fix for
wobbly fuses. It's the 'last resort' if you're not willing to take a lot
of time. I'm not sure if this has anything to do with your real problem
'Curly'
saltydad58
Guest
Posts: n/a
Thanx for the response, but the problem is in or around the fuel cut-off
relay. No electrical to the fuel pump, and I'm stymied.
saltydad58
Guest
Posts: n/a
Old Aug 27, 2005 | 08:59 PM
TeGGeR®
Guest
Posts: n/a
news:c0ab082cd9c6052105cc8e834544d968@localhost.ta lkaboutautos.com:
Do you have a carb?
TeGGeR®
saltydad58
Guest
Posts: n/a
Yes, it's carburated. I'm thinking the problem is electrical in nature -
most likely in the fuel cut-off relay.
Old Aug 28, 2005 | 08:31 AM
TeGGeR®
Guest
Posts: n/a
news:3ab5405bef3b5fdf3debe6718d9fab48@localhost.ta lkaboutautos.com:
Ah, then you do not have an EFI Main Relay, since you don't have EFI.
TeGGeR®
Old Aug 28, 2005 | 09:30 AM
B Squareman
Guest
Posts: n/a
"saltydad58" <saltydad1@nospam.cox.net> wrote in message
news:3ab5405bef3b5fdf3debe6718d9fab48@localhost.ta lkaboutautos.com...
The fuel cut-off relay for the carb uses the tach signal from the coil
(blue wire) in order to keep the fuel pump going. No blue wire, no pump.
The solution is to probably to get a new coil.
B Squareman
Guest
Posts: n/a
Want to get it started by Monday morning. Do what Preludeprob
did, heeding Jim's warning.
http://groups.google.com/group/rec.a...31f4b56c5a109f
saltydad58
Guest
Posts: n/a
Thanks for all the suggestions - especially to Curly Q and B Squareman. I'm
thinking the coil may be the direction to look. No battery juice to the
blue wire, and we are not going anywhere; and the weather has been hot
here. Today's project: replacing coil. I'll let you know the results.
seattleguy
Jun 19, 2018 07:00 PM
mikestvn
Dec 15, 2015 01:41 PM
Aw
Sep 12, 2005 03:40 AM
jpmp
Sep 10, 2005 08:43 PM
cocococo1
Jun 23, 2005 11:43 PM
