Progress Auto Rear Anti-Sway bar! WITH DIY PHOTOS PAGE 5!
Old Jul 21, 2007 | 10:05 PM
  #241
carlosalicea's Avatar
Originally Posted by azkikersfit
so at wat speed does the car oversteer? will the car oversteer when driving about 70mph and makin small turn like on a curvy or windy road?
probably like 25 to 35 degree turn? just wondering if the car willl start oversteer at a certain speed, just to be on the safe side cos i do alot of highway driving at 70 to 80 mph. and i dont wanna be spinning or wiping out
No.
The car will oversteer only if you want it to, but you 'll have to take it to 13/10's to provoke it... You are perfectly safe!!!
Old Jul 21, 2007 | 10:59 PM
  #242
manxman's Avatar
X2 for comments from Carlos and Mx. You'll be very happy next time you're doing 75-80 mph in a stiff crosswind also. No more rubbing mirrors with the car in the next lane.
Old Jul 22, 2007 | 12:39 AM
  #243
sydeshowbob's Avatar
got my swaybar in and had to wait a few weeks to install - did it tonight with help of a couple friends. I cannot believe the difference, it feels like a totally different car - and well worth the money. the only thing i was worried about was the way the rubber pads sat on top of the bolts - but i suppose since no one has had problems then it should be ok. Very easy to install and way kewl...
Old Jul 23, 2007 | 09:43 PM
  #244
dank24's Avatar
I always got told to not install sway bars unless you have at least the car lowered. but some of you have installed it? Is that safe?
Old Jul 23, 2007 | 10:08 PM
  #245
manxman's Avatar
No, We're all going to die.
Old Jul 23, 2007 | 10:17 PM
  #246
Wave's Avatar
Order placed!
Old Jul 23, 2007 | 10:33 PM
  #247
dank24's Avatar
ha, thanks for the wise ass answer . but really anything over 21mm (even 21mm is large)should have some type of sub frame reenforcement since it could attentionality damage or even rip or tear out under hard conditions.
that is why i asked about the stock suspension
Old Jul 25, 2007 | 12:27 AM
  #248
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I have to post about this.... So, today I put my Eurosports back on. 15x6.5in with 215/50/15's.
I must say HOLY****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!
I have NEVER EVVERR felt my Fit handle this way. Took this S bend at 40mph entering then accelerated through out the bends. Not once did I brake or let off. On the throttle through both turns.
Tires didnt sound or even show signs of starting to break loose.
Again; HOLY****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
14's and 60series tires FTL. They looked good though.
Whats it going to rip out? Its mounted on the rear spring perches. Its mounted with 3 bolts on each side. Its pretty sturdy, it isnt going anywhere. If it rips out or breaks something Im sure Progress would pay for the damages.
Old Jul 25, 2007 | 12:34 AM
  #249
dank24's Avatar
its not mounted to the sub-frame? I had a 22mm on my ek, but I had a lot of suspension work done to it so it did not have as much play as a stock suspension would. I know with the civic's sway bars were attached to the sub-frame, and if it was not reinforced or major suspension work done to reduce the shifting it would rip out of the sub-frame where the sway bar was bolted.
Oh 3 bolts too. ok, I take back what i said. I guess it could still happen, but not likely with 3 bolts. Unlike on civic's the one bolt on each side attached to the sub-frame.
Old Jul 25, 2007 | 01:01 AM
  #250
Posts in the NUUDE
Nope, its only mounted to the spring perches with 3 thick bolts on each side
Its very sturdy.... Progress did their research.
Old Jul 25, 2007 | 01:14 AM
  #251
dank24's Avatar
guess I will be ordering one soon. Want to do my whole suspension at one time. Hit it and run lol
Old Jul 25, 2007 | 04:09 PM
  #252
leandro82's Avatar
Anyone using GF210's with this? I might put off my springs installation to get the bar.
Old Jul 25, 2007 | 06:09 PM
  #253
leandro82's Avatar
Old Jul 25, 2007 | 07:07 PM
  #254
manxman's Avatar
Originally Posted by leandro82
You made a good decision. Lowering the car will make far less difference in handling than the bar.
Old Jul 26, 2007 | 02:28 PM
  #255
leandro82's Avatar
Wow you are like scary-sold on the bar, huh?
For $140 I figured why not give it a shot. Only thing left to do will be wheels after this.
Old Jul 26, 2007 | 03:07 PM
  #256
dank24's Avatar
I thought he was being sarcastic? lol i dunno
Old Jul 27, 2007 | 04:24 PM
  #257
NewEdgePerf's Avatar
I was thinking the same thing!
Originally Posted by 2hot6ft2
Those pics are too funny. Wonder if people driving by thought you were stuck.
If you need those bars, I have them as well.
Tony D
Old Jul 27, 2007 | 09:09 PM
  #258
Jimmy101's Avatar
Perhaps someone can comment how the progress bar works with GF210 springs. Will the rear be to stiff?
Old Jul 27, 2007 | 09:18 PM
  #259
dave brown's Avatar
Once I drove my car off the ramps I noticed the stiffness of the rear end. Almost feels more stiff than the front.
Over larger dips my sway bar makes noise, but thats easily fixed with the knob on the radio.
Does anybody elses bar make noise?
Is there an issue w/ the bar hitting the gas line?
Old Jul 27, 2007 | 09:41 PM
  #260
manxman's Avatar
A bar that makes noise is not installed properly, or springs were not reinstalled properly in the bar installation. There is no noise issue with this product. It does not hit fuel lines if installed properly.
