Drive Belt Replacement Honda Accord 93 LX
Old Jul 22, 2007 | 05:24 AM
kamehamehaaa's Avatar
Hello everyone
I have a Honda Accord 93 LX and I believe I need to change my drive belt/serpentine/fan belt whichever its called. Its tearing from the right side of the belt. Anyway can someone give me some information on how to change my drive belt. What must I know before approaching this. Can someone provide me a general step by step instruction on how I should remove and reinstall the belt? Also where I can find a belt diagram because I dont think my car has one. How do I check for tension after I replaced it?
Thanks for the help
kame
Old Jul 22, 2007 | 01:16 PM
manxman's Avatar
Originally Posted by kamehamehaaa
Hello everyone
Thanks for the help
kame
Invest in a genuine Honda repair manual for the car. Generally, drive belts have one pulley somewhere in the system of pulleys that applies spring tension on the belt to keep it aligned and properly tensioned so that it does not slip. By moving that tension pulley the right direction with either a breaker-bar or long torque wrench, the tension is removed and the belt now has enough slack to allow you to remove it from the rest of the pulleys. Finding the tension pulley is EASY with the manual, as are MANY other repairs, and the manual will pay for itself almost with your first repair job (in labor savings vs. dealership/mechanic).
grommet
Apr 27, 2026 09:57 PM
mikejet
Sep 22, 2021 11:04 PM
Marrk
Apr 11, 2017 10:52 PM
hazzard
Nov 20, 2013 01:38 AM
