Probably Been Asked. 13's?
Old Jul 26, 2007 | 04:22 PM
MarkyMark's Avatar
Originally Posted by Mx6GT89
I was actually told about these yesterday, no they wont fit. Offset is WAY too high and the way the rims are designed the calipers will hit the spokes.
Coudn't you just get some spacers?
Old Jul 26, 2007 | 05:32 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Yes you could. Depending on the size of the spacers sometimes extended wheel studs are needed.
I know on Eg Civics and Integras people run Hx wheels. They shave down the calipers for them to fit. The only real problem with high offset is caliper clearance.
Old May 20, 2008 | 02:33 PM
Sugarphreak's Avatar
Push My Button
BUMP!
I know, old thread But 13's have caught my interest (I blame Solbothers ) and I want to find out if anybody has had any luck getting these to fit.
I worked out you can run a diameter of around 21", that is 3" smaller than stock and gives you 1.5" of extra shock movement in the fender gap which might be enough to run whatever crazy width and offset you desire.
The question remains, has anybody been able to get 13's around the stock caliper?
Old May 20, 2008 | 03:46 PM
GD3-Fit's Avatar
I <3 SPOON
wow
13's=so sick
i'd like to see how this turns out
-Ricky
Old May 20, 2008 | 05:47 PM
Posts in the NUUDE
Youll need to grind down the calipers. I dont know how much but deff a good amount.
If youre willing to do it go for it.
Only way Id pick up 13's for my Fit is if I found some nast wide ones. I dont even look for 13in wheels so..... yea, I wouldnt find any. Hahh!
Another problem with doing this is what size tires are you going to run?
13's arent really a common rim size now-a-days.
Pretty sure I posted about this, I tried some 13in steel wheels and they almost cleared the calipers. All rims are different though. So you wont know unless you bought the wheels and measured how much needed to be ground down.
Old May 20, 2008 | 05:51 PM
Push My Button
Tire is easy
Hoosier makes an A6 and an R6 in 225/45/ZR13 that would be perfect
Also a street option:
Sumitomo HTR 200
Old May 20, 2008 | 06:08 PM
Posts in the NUUDE
I ment street wise. So thats one street tire? I know EdgeRacing has a lot of different tire options. Or at least they can get them.
215/50's arent too bad. Wide and the tire profile isnt too big. However itll still be a damn chunky tire due to a 13in wheel. Hehh
The 225/45's is a sick size. I wouldnt care if they were slicks/comp tires Id roll them daily!
Old May 20, 2008 | 07:53 PM
Whitehybrid's Avatar
those wheels are sick...
start shaving down your calipers son..
Old May 27, 2008 | 11:30 AM
GD3-Fit's Avatar
I <3 SPOON
any updates on this??
i wanna see 13's!!!!
-Ricky
Old Jun 4, 2008 | 08:06 PM
1 Sick Fit's Avatar
you should do something that looks like this:
it would be so sweet to see a fit rolling around like that.
Old Jun 4, 2008 | 08:12 PM
Posts in the NUUDE
I havent tried to do 13's yet. But the only way Id run them is if they were 7in and wider.
And some nice offset as Ill need it for help clearing the calipers.
Old Dec 22, 2013 | 09:58 AM
  #32
devmail's Avatar
So has anyone tried the civic vx wheels with spacers?
aqua-holic
Jan 12, 2011 09:41 PM
Tofuman
May 20, 2008 03:44 PM
ir13
Jan 7, 2008 10:26 AM
j5ive
Car Shows, Events, and Racing
Apr 13, 2007 08:10 PM
Bounty Hunter
Nov 21, 2006 11:57 PM
