View Single Post
  #2 (permalink)
Old 08-11-2007, 12:53 PM
JDMchris.com's Avatar
JDMchris.com JDMchris.com is online now
I run THIS
JDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to live
Send a message via AIM to JDMchris.com
I shouldve when I installed my friends.
Anyways, with the Spoon spoiler you receive a Template that go on either ends and one in the middle. (I cut out the middle bolt so i didnt have to drill 3 holes.)
Once the Templates are in place test fit the spoiler, make sure the bolts will line up on the template.
Next you can use a punch to keep the bit in place, or just start drilling.
I would recommend gettting some touchup paint and paint the raw metal after drilling to avoid rust.
Would also recommend some doublesided tape for the middle of the spoiler altho its not required.
Open up the hatch and place the nut/washer on the bolt and tighten and your done.
__________________
KRAFTWERKS Kit Owner #1
www.Kraftwerksusa.com BOOOOOST!!!
www.skunk2.com Best Coilovers!!!
www.Robearracing.com Rob is the Man!!!
www.prmracing.com Best intake on the market!!!!
www.teammfactory.com LSD and Final Gears!!!!
EPIC BUILD
IHFP!
JDMchris.com's Sig Specific Sub-Forum
