Radio install help
Old Sep 15, 2007 | 11:29 PM
Crawly's Avatar
Radio install help
Ok, this is what I need to hide somewhere.....
Alpine TUA-T500HD HD Radio tuner for select Alpine stereos at Crutchfield.com
any ideas? It's bigger then the Sirius tuner and is a goofy shape. The only place I've come up with so far is under the drivers seat. It will clear fine, but I don't really want to run the cables from there to behind the radio. Call me lazy.
I can't seem to find anywhere else to put it though. I was hoping one of you guys or gals that had an amp or something of a similar size installed could show me where you put it. Any help or thoughts are appreciated. Thanks!
Old Sep 15, 2007 | 11:35 PM
abcsr2ez4me's Avatar
if you can actually find something that clears the front seat... do it.
Old Sep 16, 2007 | 02:00 PM
Injundon's Avatar
Mount it under the drivers side dash. There's ALOT of free space in there. just be sure to tie wrap it up so none of the pedals run on the wiring.
Old Sep 16, 2007 | 07:39 PM
Crawly's Avatar
That's what I was originally trying to do, but I can't find a way ti mount the HD radio tuner. Frustration is at an all time high. I'm almost to the point of letting someone else do it so if anyone has any other ideas or suggestions, spit them out. I'm not sure what else to do here, I'm pretty much beaten.
Old Sep 16, 2007 | 09:26 PM
Injundon's Avatar
Under the drivers dash..there's tons of room there.
You should see how much requipment is burried in my beetle. The fit has soo much free space to hide things. I have my Sirius KCA-SC100 with the sirius tuner box which is seperate KCA BT-300 as well as an audio control DQT. The DQT is really big and is located under my drivers side dash. clears all the pedals and the steering column just fine.
Old Sep 17, 2007 | 12:21 AM
Crawly's Avatar
Really? I'd love to put it over there. Could you maybe post some pictures of how you've got that stuff installed so I can get an idea? That qwould help alot. I must be trying to install it in the wrong area lol Thanks!!!!!!!!!!!
Old Sep 17, 2007 | 02:10 AM
Injundon's Avatar
Just remove the cover under the dash and you'll see dude
Old Sep 17, 2007 | 11:25 AM
Crawly's Avatar
I did take the cover off, but the HD box is too bulky to put anywhere under there. I'm going to go look again now that I've got some daylight.
Old Sep 17, 2007 | 11:48 AM
koolkevin1107's Avatar
from the dimensions of the box, it looks like it will fit behind the stock headunit. its only 7-13/16"W x 1-3/8"H x 7-7/8"D in dimensions. If not, there is definitely TONS of space underneath the drivers side dashboard where the steering column is.
Old Sep 17, 2007 | 12:37 PM
Crawly's Avatar
That's a good thought too Kev, I'll go take a look. I think it would fit in several places behind the drivers side dash, but its too odd of a shape wo wedge it anywhere. Basically, there's spots where it would fit, but you cant get it there lol
Old Sep 17, 2007 | 01:25 PM
Crawly's Avatar
yea ok this isn't working and I'm running thin on patience. Maybe I could install it in the garbage can
Fit freak242
Nov 6, 2013 10:44 PM
LoveMyFit49
Mar 10, 2013 12:59 AM
damoaten
Feb 28, 2013 11:09 AM
melohyeloh27
Oct 2, 2008 10:30 PM
Crawly
Aug 14, 2007 10:31 PM
