HELP NEEDED! driveshaft...
Old Sep 29, 2007 | 04:02 AM
k3_'s Avatar
k3_
Just tried to install to my new coilovers and driveshaft went out. Did a search, I tried the recommended twist and push for 1hr but no luck so far.
Are there any other options I should try?
I dont really want to cut the rubber at this moment or at all.
Thanks in advance.
Old Sep 29, 2007 | 05:31 PM
koolkevin1107's Avatar
keep trying! it take a while. it took me and my lil brother 1.5 hours to get the drivers side back in. try putting a jack under the lower control arm and lifting it until it's parallel, then try it again.
Old Sep 29, 2007 | 07:28 PM
k3_'s Avatar
k3_
thanks. ill take another stab at it.
although sometimes it feels pointless as it keeps on hitting something
Old Sep 30, 2007 | 04:02 AM
Sugarphreak's Avatar
Push My Button
This happened to me too he he... oops! I didn't want people to know this... but to help a fellow Fitfreaker I guess it is worth it.
Anyway, I wrestled with it for hours and was convinced I screwed it up for good. I finally managed to get it back in my lifting the whole assembly up much much higher that I was before and ensuring it was prefectly straight. The best position is to straddle brace it with your both your knee's, lift it up and push in and out softly while twisting slowly (sound like something else I like to do!).
Don't Cut the Rubber!! Just cut the banding!!!
I also removed the boot and re-packed the joint. I used hose clamps on the boot until I got a banding kit, if you do this you need to ensure the clamp screws are opposite of eachother so you can minimize the eccentric weight until you get it fixed.
Old Sep 30, 2007 | 11:32 AM
fit4kris's Avatar
Yup....I had to cut the banding because I am impatient! I got a new banding kit, repacked the bearings and all has been good for 7K miles so far. Good luck.
Kris
Old Oct 2, 2007 | 05:32 PM
k3_'s Avatar
k3_
Thanks for the advice guys.
Update: I did manage to get the axle back in, however I had to cut the band off. I don't know how many hours I tried to push the bloody thing in but it wouldn't just go in. As I took the axle out, I found out one of the bearings where off.
I will try to take some photos soon of the new ride dumped.
Its on tein super compacts
Cheers
Old Oct 2, 2007 | 08:10 PM
ChrisN's Avatar
Frequent FitFreak Poster
Lesson learned! I had a hard time putting that sucker back together too after two agonizing hours of sweating, pissing, cursing and a couple of beers...LOL. I also put a circular hose clamp on the boot.
I feel bad about the axle, it's not originally the same anymore!
Old Oct 2, 2007 | 10:21 PM
kelsodeez's Avatar
UNBANABLE
this really is a design flaw that honda needs to be aware of. i think every person i know with this car that has done suspension work has had this problem. i got my driveshaft back in after a few hours of screwing around with it but i accidentally ripped the rubber boot. its a big problem that i hope they have addressed in the 08 models. probably not though
Old Oct 2, 2007 | 10:26 PM
JDMchris.com's Avatar
I run THIS
Supporting the axle up with a jack will help prevent the problem. But yes the axle slips out easier than other Hondas.
Old Oct 2, 2007 | 10:28 PM
SPON FIT's Avatar
im not sure what you guys are doing but i didnt have any issues with the axle pooping out.just put a jack on the rotor to hold the whole thing up and your good
Old Oct 2, 2007 | 11:49 PM
ChrisN's Avatar
Like I stated: "Lesson learned". Now I know. Thanks guys!
Old Oct 2, 2007 | 11:52 PM
Mdelro1's Avatar
does this only happen on the driver's side?
Old Oct 2, 2007 | 11:59 PM
ChrisN's Avatar
Yes on my Fit. Don't know about others.
Old Oct 3, 2007 | 12:09 AM
jeffquach's Avatar
mine popped out on the passenger's side. PITA...
Old Oct 20, 2007 | 04:41 PM
HONDAMATIC's Avatar
yup i used a box wrench and a lugnut to prop up the steering knuckle, cuz my jack was holding the car (not safe, do not try at home!!) ahaha
cab0053
Nov 21, 2016 10:50 AM
Fit_Mike
Jun 6, 2010 10:49 PM
Sam Misled
18
Dec 4, 2008 04:01 PM
dewthedew
Sep 7, 2008 04:44 PM
pokems23
May 30, 2008 11:52 AM
