rear spoiler replacement??
Old Oct 2, 2007 | 10:53 AM
07fitsport's Avatar
has anyone replace the factory rear spoiler that over the hatchback part (guess that is called the roof spoiler?) ..what did u replace it with and did u have to drill holes in the new one or does it screw in from under neath ?
what all did you have to do to install?
Old Oct 2, 2007 | 12:53 PM
Illusive's Avatar
I got the VTi-S Spoiler. No new holes, two screws attached to the spoiler that go into the outer two existing holes.
Old Oct 2, 2007 | 12:58 PM
07fitsport's Avatar
where did you get it and what was bout the cost of it....
how did you install it was it screws that screwed up from underside of hatch? doesnt the factory spoiler bolt from roof down?
JDMchris.com's Avatar
I run THIS
however if you put on spoon or mugen spoiler you will HAVE to drill into the hatch.
Old Oct 2, 2007 | 01:04 PM
07fitsport's Avatar
that is what i am trying to avoid (dont wantto drill) and find a direct replacement that is little different in style or bigger
Old Oct 2, 2007 | 01:07 PM
I run THIS
looks like your best bet is that VTi spoiler.
Old Oct 2, 2007 | 01:08 PM
07fitsport's Avatar
where can i get one to fit a us 07 fit sport
Old Oct 2, 2007 | 11:41 PM
GSRswapandslow's Avatar
do they come prepainted?
i'd deff be interested in a TW one
Old Oct 2, 2007 | 11:42 PM
I run THIS
hit up ben or dickson at aj-racing.com
Old Oct 3, 2007 | 12:25 AM
Illusive's Avatar
Hit up Ben at AJ, he is the Fit specialist!
Old Oct 3, 2007 | 01:33 AM
Mynute 1's Avatar
Senior Member
What about the Fab spoiler? Would that be a direct replacement, or would new holes need to be drilled?
Old Oct 3, 2007 | 01:58 AM
I run THIS
im sure the fab spoiler also needs drilling
Old Oct 3, 2007 | 01:59 AM
Mugen_Dom's Avatar
Ben from A&J can get you one as that's where Illusive got his from.
Old Oct 3, 2007 | 02:03 AM
how much do they cost?
Old Oct 3, 2007 | 03:47 PM
Mugen_Dom's Avatar
I don't know. Check with Ben or Illusive.
Old Oct 3, 2007 | 06:29 PM
Illusive's Avatar
Ehhhh I'd ask Ben. I got the first and only one he brought in, so if he is bringing more of them in, then it should be cheaper. Attachment is through 2 screws. One on either end is affixed to the spoiler. Two existing nuts need to be re-used from the stock spoiler in the same locations.
Old Oct 4, 2007 | 09:41 AM
Wave's Avatar
Thumbs up Looks GREAT!
Did yours come pre-painted VBP?
Does the entenna get in the way when you open the rear?
No problems with the rear windshield washer arm?
FitGD4
Oct 11, 2013 02:46 AM
jvm051
Sep 14, 2008 04:29 PM
GlennD
Jun 17, 2008 03:04 AM
TeamStaNceFIT07
Feb 29, 2008 09:05 PM
07fitsport
Oct 2, 2007 10:53 AM
