'86 honda civic's steering wheel seems to be getting stiff.
Old Oct 4, 2005 | 02:31 AM
wannadoitmyself
Guest
Posts: n/a
My old backup car, an '86 civic is getting harder to turn the steering
wheel. When I turn either to the left or right, after comencing to go on a
straight road, the steering wheel seems to keep being turned to either
direction. I adjust it hard enough, but if for instance I had turned
right, then when I adjusted it to the left it may want to stay to the
left. The car's response when "avoiding potholes" is not as quick. Unless
I turn it hard but I know this is not normal. Can anyone please give me
some advice on what the problem may be? Thank you.
Old Oct 4, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
Re: '86 honda civic's steering wheel seems to be getting stiff.
ball joint seizing up.
Old Oct 4, 2005 | 02:30 PM
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:59OdnSpiI8A76t_eRVn-pw@speakeasy.net:
>> steering wheel. When I turn either to the left or right, after
>> comencing to go on a straight road, the steering wheel seems to keep
>> being turned to either direction. I adjust it hard enough, but if for
>> instance I had turned right, then when I adjusted it to the left it
>> may want to stay to the left. The car's response when "avoiding
>> potholes" is not as quick. Unless I turn it hard but I know this is
>> not normal. Can anyone please give me some advice on what the problem
>> may be? Thank you.
And we know what a barrel o' fun that is...
http://www.tegger.com/hondafaq/misc/...int/index.html
TeGGeR®
Old Oct 5, 2005 | 09:34 AM
wannadoitmyself
Guest
Posts: n/a
Thanks all of you once again for your advice. It was very accurate. I found
this out just yesterday, as I went to school and when I got to the parking
lot, as I was turning right to get in the parking spot the wheel came off!
because the ball joint popped out. I am glad it didn't happen down on the
highway at 70 mph.!!! Thanks for your advice. Lesson learned.
zeniitti
Aug 31, 2017 03:34 AM
JJIN
Dec 26, 2010 01:41 AM
hobbes87
Oct 30, 2010 10:57 PM
luv4jdm
Feb 23, 2009 01:19 PM
shyamsadhwani@gmail.com
Jun 4, 2005 11:09 PM
