Sponsored by:
Sponsored by: CARiD
Raising the driver seat, anyone have suggestions?
Old Oct 6, 2007 | 10:59 PM
Ritzbury
Guest
Posts: n/a
Question Raising the driver seat, anyone have suggestions?
has anyone raised the front seat? i'm looking for an inexpensive way to life it 1.5 or 2 inches higher. anyone have suggestions? are the bolts long enough to put a spacer in under the seat between the floor?
Old Oct 7, 2007 | 01:16 AM
Injundon's Avatar
It's possible to add a spacer to the seat rails. I wouldn't try spacing it at the floor mounts. You'd need to buy some grade 10 bolts of the right size/thread. Just be warned that this could cause your seat to break loose in the event of an accident.
Old Oct 7, 2007 | 10:32 AM
Ritzbury
Guest
Posts: n/a
I am planning on being very very cautious about it, since the gas tank is right under the seat. i might get longer bolts of the right thread, and put a spacer in. i'm about to check it out when it get's warmer outside
Old Oct 7, 2007 | 12:18 PM
Cat's Avatar
Cat
Have you thought about just getting a seat cushion to give you a few more inches of height? There are several good products on the market which would bring up your height but not alter the seats.
Cat :x
Old Oct 9, 2007 | 10:08 AM
Apex77's Avatar
Phone book
Old Oct 11, 2007 | 12:40 PM
Nabisco's Avatar
Senior Member
Just curious as to why you wish to raise the seat height. I think the seat feels a little too high myself. Perhaps I'm used to older Hondas.
Old Oct 11, 2007 | 02:05 PM
TOOL's Avatar
The seats super high already IMO....But get like a booster or something??
Old Oct 11, 2007 | 02:50 PM
Ritzbury
Guest
Posts: n/a
oh, because i'm 5'8'' and my legs are abnormally long for someone my size. my feet are at a weird angle to get the pedels. i want to raise it to correct that angle.
i tried on sunday. it wouldn't work anyways. the bolts are all angled perpindicular to themselves.
Old Oct 17, 2007 | 11:53 PM
aallbbeerrtttttt's Avatar
Good old yellow pages trick =P
But seriously, I would want to LOWER the seating position of my seats.
Old Oct 24, 2007 | 08:57 PM
BlackCobra's Avatar
If you lower it then would it affect how the seats suppose to function like when you lay the seats flat?
Old Oct 27, 2007 | 12:40 AM
EyesofFreedom's Avatar
If you hit hard enough to brake a 10 bolt you probably wouldnt live through the accident anyways...
Old Oct 27, 2007 | 12:44 AM
Injundon's Avatar
With a 1" Dowel the sheer potential makes a grade 10 9.5MM Shaft(14mm head typical) bolt pretty weak.
Old Oct 27, 2007 | 02:09 PM
PizzaFit's Avatar
Have you talked to your local Honda Service department? Perhaps a rail from another Honda vehicle will fit and might have a higher seat placement. If not, try a custom seat pad.
Old Nov 9, 2007 | 04:23 AM
storm88000's Avatar
Frequent FitFreak Poster
You guys really think the seats are already too high? I think they're too low, although I'm also about 5'8" like the OP.. would like a nice inch or two raise..
Old Nov 11, 2007 | 02:55 PM
solbrothers's Avatar
maybe sit on a phone book?
Old Dec 15, 2007 | 02:00 PM
swigeric's Avatar
yeah try being 6'...im coming from a honda element that had a height adjustment knob on the drivers seat...every time i get in the fit the seat bolsters are to tight, the seat is to low and the lack of a deadpedal makes my ankle turn sideways.....kinda ironic that they call this car a "fit".
Old Dec 16, 2007 | 04:50 PM
kodo's Avatar
is there a way to lower it? i am too use to old civic lower
Old Dec 16, 2007 | 05:18 PM
Ritzbury
Guest
Posts: n/a
i know they've talked aobut lowering it on here, but it will be tricky since the gas tank is right under the driver seat
Old Jan 10, 2008 | 02:58 PM
Skimmer's Avatar
Can you be more specific? What do you mean by 'perpendicular to themselves'?
I would like to just raise the front of the driver's seat slightly to give the seat bottom a little backward tilt. I'm 6'1" and think that would be more comfortable for working the pedals while allowing me to keep the seatback where I want it to reach the wheel. I wish Honda had provided this kind of adjustment from the factory. The otherwise cr*ppy Hyundai cars I drive at work have wonderful adjustability like this using two knobs on the side.
Old Jan 10, 2008 | 06:38 PM
Ritzbury
Guest
Posts: n/a
the bolts are at an angle, pointing outward from eachother. if it's the back tilt you are looking for, you can easily do that, with possible modding or bending the front bracket. just loosen the bolts or take a good look, and you'll know what i was talking about.
