DIY: Putting the headlights back together
Old Oct 28, 2007 | 10:33 AM
smeister's Avatar
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
You need to reassembled the painted plastic cover and the lens of the headlight.
Do the reserve from https://www.fitfreak.net/forums/fit-...eadlights.html
I ordered this butyl sealant for tail lights from the Nissan dealer. You can see the part number in the picture if you want to order it. Claymore also shined some light on this butyl sealant and you can get it from the autoparts store. It's the window sealant, which is also butyl based.
I dont know if you can tell, but I put a thin strip all around the crack where the butyl should go before I put the headlight back together and in the oven.
After I preheated the oven to 200C and turned it off, I assembled the headlight back together as best as I could for now and placed it inside the oven for 10 minutes. After that I took it out and just pressed it back into the crack and slipped the plastic clips back into their places. AGAIN, your oven may vary from my oven so check it in 5 minutes and see if any plastic is melting.
After all is pressed back together, put the three screws back into the back of the headlight.
Here's a pic of a completed vs incompleted headlight.
Old Oct 29, 2007 | 04:18 AM
claymore's Avatar
A continuing very good DIY by smeister!!
Old Jan 20, 2008 | 10:47 PM
smeister's Avatar
I just found out more details about the butyl sealant from the autoparts store from Earthmover84.
"you can put on your DIY that 3M Windo-Weld Ribbon Sealer works to, just got some. it does contain polybutylene, and butyl. thought i might let you know. AutoZone and Advanced Autoparts both carry it. part number 051135 08612" - Earthmover84
Old Mar 14, 2009 | 11:48 AM
porkchop's Avatar
200 celsius or fahrenheit
200 celsius sounds way to high
Old Mar 14, 2009 | 12:04 PM
koolkevin1107's Avatar
farenheit.
Old Jul 4, 2009 | 07:51 PM
OneStopCustoms's Avatar
to the top
Super Mario
Jul 6, 2015 06:56 PM
2008StormyFit
Mar 13, 2014 06:36 PM
Loevess
Jul 28, 2010 09:59 AM
joemama4646
Oct 13, 2008 03:40 PM
smeister
Oct 26, 2007 10:25 PM
