E-Brake Adjustment???
Old Mar 29, 2009 | 05:46 AM
7red7's Avatar
Hey all!!!
I did a search and was unable to find anything on e-brake adjustments. My e-brake doesn't really begin to grab the first three or four clicks and has a total of 8-9 before it's firmly set. I know that ideally somewhere between 5-7 is what it should be, and I'd like to tighten it up.
Can I access the cable tension bolt from under the center console? If so, does anyone have a diy for performing it? Thanks in advance for any assistance on this one
HAPPY DRIVING!!!
Old Mar 29, 2009 | 11:18 AM
AMMF's Avatar
I don´t no about you guys in the states but here in Portugal Honda substituted almost 2005 Jazz E-brake. Because they say it could set free when parked. If your E-brake doesn´t start to grab it could be dangerous. If i were you i´d look for advise in you´re local Honda dealer.
Old Mar 29, 2009 | 11:41 AM
Type 100's Avatar
Originally Posted by 7red7
Hey all!!!
HAPPY DRIVING!!!
Is your Fit a GD or a GE?
I've disassembled the center console on my GD1 Jazz, and you can indeed access the handbrake cable and its adjuster from under the center console.
On the GDs, removing the center console is rather easy - all you need to do is remove a couple of clips at the front footwells and a couple of screws beside the front seats. You also need to remove the little plastic tab under the handbrake and take out the jack for the 12V power socket, so you can remove the whole console, which is one large piece of plastic.
HTHs
Old Mar 29, 2009 | 01:47 PM
gimme's Avatar
Master FitFreaker
thanks Type 100...i was assuming that is where it is, but wasn't sure.
Old Mar 30, 2009 | 03:36 AM
Type 100's Avatar
No problemo. Sadly I didn't have photos of the area under the center console, but removal should be easy enough.
If you've had any other older Hondas, like 1994-97 Accords, you can see the handbrake cables live around the same area too.
Old Apr 4, 2009 | 03:52 AM
richard612's Avatar
Don't bother with the e-brake cables. You can tighten the shoes themselves (remove the drums) and accomplish the same thing. I get e-brake action at the very first click now.
Old Apr 9, 2009 | 08:07 PM
FITTECH's Avatar
Hey guys just to let you know honda spec is 8-10 clicks on the E-brake handle. You may risk rear brake overheating or cable stretching if not set correctly. So beware.
Old Apr 10, 2009 | 03:54 AM
richard612's Avatar
Drums aren't getting excessively hot. Parking brake holds just fine. Cable still operates the same as before.
I'll keep you guys posted.
Old Apr 10, 2009 | 07:38 AM
gd3vbp's Avatar
The only adjustment I knew about on drums was for the actual pads not the parking brake? Is it the same adjustment point?
Old Apr 11, 2009 | 01:02 AM
richard612's Avatar
It's the same point. Getting the pads (shoes, actually) closer to the drum has the same effect as adjusting the cable. After tightening, it takes less cable travel to fully engage the shoes against the drum.
Old Apr 11, 2009 | 11:27 AM
gd3vbp's Avatar
Good to know, I don't work with drums very much, but I suppose I'll have to start with this car.
Old Apr 12, 2009 | 09:31 PM
Type 100's Avatar
You can go as low as 7 clicks, as per the Fit/Jazz Electronic Service Manual. Agreed on the 10 click limit though.
saiko
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 13, 2015 11:52 AM
Toscha
May 5, 2010 10:06 AM
m11a1
Mar 7, 2009 12:04 PM
SiLo
Feb 22, 2009 01:01 PM
chinese
Aug 27, 2008 02:54 PM
