replacement stone gaurd?
Old Jun 30, 2009 | 04:32 PM
thesplashfactor's Avatar
I had an unfortunate run-in with a low clearance speed bump and royally messed up my stone guard (plastic piece under the front bumper cover. this is no biggie is suppose except that it is a single piece with the front wheel well guards. I want to replace it before cold weather and salted roads corroding my body. anyone know what the part name/number is for this thing or where i could get one? i have scoured sites like college hills honda to no avail.
Old Jul 1, 2009 | 11:54 AM
you mean the skid plate?
Old Jul 1, 2009 | 06:15 PM
2trips's Avatar
I also ripped that off (and both plastic wheel well guards) while off-roading.
I plan on adding a sheet metal skid plate and a tube frame bumper while I'm at it. It doesn't snow here so I can do it at my leisure.
Old Jul 1, 2009 | 08:30 PM
Fit4Trav's Avatar
How did you rip that off on a speed bump? Im super low and have not ever had that skid plate ripped off. How fast were you going?
Old Jul 3, 2009 | 05:50 AM
HONDAMATIC's Avatar
its called the spash guard/ shield
Old Jul 5, 2009 | 07:20 AM
Rob22315's Avatar
Found it
Honda part number 74111-SLN-A00. Bernardihonda has it. Collegehills can probably get it too if you search by PN. It's pretty cheap - $39.13. Don't forget to buy the clips.
Old Jul 5, 2009 | 10:36 AM
Type 100's Avatar
Had a feeling it was the splash shield...just wanted confirmation. Not sure if we share the same part number though.
Anyway I DIY-replaced mine. This is true: Don't forget to buy bumper clips. You'll need at least 6 of them. Two go into each fender behind the front wheels (so yes, front wheels off when you replace the splash shield), and at least two of them reside under the engine itself - I don't remember exactly how many clips I used on the underside.
Try getting a ramp or at least two jackstands or scissor jacks if you want DIY replacement.
Good luck!
Old Jul 5, 2009 | 02:42 PM
secondspassed's Avatar
Requesting a photo DIY when you get the part! I'm afraid this may happen to me as well, someday.
Old Jul 6, 2009 | 02:58 AM
Type 100's Avatar
If you have the Fit/Jazz Electronic Service Manual, the instructions are there. Finding them is not straightforward though. The splash guard removal procedure is part of another, and sadly not an article in itself
If I remember correctly it was an article under the "Engine" category.
Old Jul 10, 2009 | 08:46 AM
E = Mc2's Avatar
I hit a truck tire tread (say that three times fast) on the Interstate and ripped the leading edge off from under the bumper cover (71105-SLN-A00). The next day, I pulled the two screws that hold it to the larger splash shield (74111-SLN-A00) and removed it, thinking to replace it in a week or so. On the way home from work a couple of days later, I started hearing something up front rubbing the road. By the time I could get pulled over to look, the large shield had caught a crack in the road and ended up under the front tire; ripping out, and taking the left inner fender liner (74151-SLN-A00) with it. All three pieces were torn or abraded to the point that I ended up having to replace them. Turns out it was cheaper for me to buy the parts at my local dealership (where they refuse to come down from list price) than to buy them discounted at Bernardi or elsewhere and pay for shipping.
I got the clips from this eBay seller. 15 of them for less than $10... shipped! FWIW, the clips that hold the bumper cover and splash shields in place are not all the same length but are the same diameter. The inner fender liner has a couple of spots that take a smaller diameter clip. (I'm still running without them)
Let's not talk about having to fix the paper thin front fender that got bent when the liner pulled out. I was able to straighten it with my bare hands!
Old Jul 10, 2009 | 03:49 PM
truck tire tread.. aka alligator. much easier to say. hahaha.
quite a damage you took on there.
Old Jul 12, 2009 | 03:04 AM
E = Mc2's Avatar
Ja, but I posted in here before about hitting a road alligator. Someone asked if we had gators in KY.
Actually, the damage was minimal at first. I procrastinated and it ended up ugly. If I'd just gone down the next day and bought the front piece, i'd have only been out $30 instead of $130. It provided a good excuse to give the wife, though: Since I was going to have it up in the air tinkering, I bought the fog lights from another Fitfreak and put them in while I was at it.
Old Jul 13, 2009 | 12:15 AM
Fit4Trav's Avatar
Now that's understandable. Im always afraid to hit "gators" cause they do massive damage
Old Nov 12, 2011 | 07:37 AM
chrisng's Avatar
anybody know where i can buy a drivers side for cheap?
degnaw
Dec 17, 2018 07:34 PM
teleburst
Aug 5, 2014 04:28 AM
cold_ukranian
Nov 4, 2011 07:17 PM
Gym Rat
Aug 28, 2009 12:03 PM
i-vtec
Oct 25, 2008 02:21 PM
