TPMS Light
TPMS Light
Hello-
I'm a happy owner of a 2008 Fit. A couple of days ago I had two new front tires installed along with a front-end alignment. All was well until driving on the highway yesterday, I noticed my TPMS light on. I had to look in the manual to see what that even stood for I've been doing dome reading up on it and I'm still not sure if this is a big deal. Does anyone have any suggestions? Is there some sort of "switch" that can turn the tire pressure sensor back on? I'm assuming that since they're new tires, that the pressure is accurate- anybody have any advice?
People who install tires often don't get the pressure right- first check the pressure, if it's the proper amount (what it says in the car, not what's on the tire) then maybe they broke a sensor- they should figure it out, whoever installed the tires.
Hello-
When you change tires the TPMS sensor is deactivated so you'll have to go to a Honda dealer to have it 'turned on'. The sensor has a built-in signal minimum of 28 psig so that if the pressure falls below that the 'alarm' light is triggered.
Its your government 'helping you out'.
PS most dealers do it for free, but some don't because they don't give a damn about customer satisfaction. If you're charged be sure to complain to Honda offices in CA
Thanks!
Thanks you guys for the advice- I took it back to the garage, they re-checked the tire pressure and all was fine. It turns out that they also replaced the tire sensor and assumed that it would automatically reset itself. My mechanic then called the dealership and confirmed that they have a special tool to reset it. Since my mechanic doesn't have this tool, I'll be going to the dealership. Thanks again for the input
Ron Belisle
23
11-03-2021 04:40 PM
carid
11-30-2017 09:04 AM
