SImple How to guide on suspension
Old Jan 1, 2008 | 03:49 PM
ghostfit's Avatar
I know i have not posted in months but i remember posting this on a different web site and thought it would be great here.
this should help anyone who want to setup there suspension for whatever they use there fit for:
Front spring rate increase:
More under steer; increase in proportional weight transfer to the front when rear wheel rate is not increased; reduces front traction when rear rate is not changed.
Usable adjustment: 150-600 lbs/in
Symptoms of too much adjustment: terminal under steer; front of car hops in corners; excessive wheel spin on inside front tire on FF cars.
Front spring rate decrease:
Less under steer; decreases proportional weight transfer to the front when rear wheel rate is not increased; increases front traction when rear rate is not changed.
Symptoms of to much adjustment: Too much over steer; over steer then under steer if spring is so soft that the car bottoms out on lean, car bottoms out excessively with a jolting ride.
Rear spring rate increase:
More over steer; increase in proportional weight transfer to the rear when front wheel rate is not increased; increases rear traction when front rate is not changed.
Usable range: 100-600 lbs/in
Symptoms of too much adjustment: too much over steer; sidestep hop in corners; twitchy; pretty scary.
Rear spring rate decrease:
Less over steer: decreases proportional weight transfer to the rear when front wheel rate is not changed; increases rear traction when front rate is not changed
Symptoms of too much adjustment: car under steers; if way to soft car under steers then over steers as car bottoms out on lean; car bottoms out excessively with a jolting ride.
Front anti-roll bar stiffer: more under steer
Usable range: none to 1.25 inches in diameter
Symptoms of to much adjustment: terminal under steer; lifts inside front tire off the ground witch can cause massive wheel spin on FF cars; also not good for most effective tire usage as inside tire is now doing nothing.
Front anti-roll bar softer: less under steer
Symptoms of to much adjustment: overstate scary; more like fun
Rear anti-roll bar stiffer: more over steer
Usable range: none to 1 inch in diameter
Symptoms of too much adjustment: Big-time over steer. Can cause inside rear tire to lift off the ground.
Rear anti-roll bar softer: less over steer
Symptoms of to much adjustment: under steer; slow and boring
Front tire pressure higher: less under steer by reducing slip angels on most tires
Usable adjustment: up to 55psi hot
Symptoms of too much adjustment: no traction- tire crowned so more under steer; adds wheel spin in FF cars; jarring ride; center of tire wears out
Front tire pressure lower: more under steer by increasing slip angles on most tires
Usable adjustment: not less then 20psi
Symptoms of too much adjustment: edges of tire wear quickly because tire is folding over; feels mushy; tires chunk because low pressure means heat build up.
Rear tire pressure higher: less over steer by reducing slip angles on most tires
Usable range: up to 45psi hot
Symptoms of too much adjustment: no traction—tire is crowned so more over steer; bad wheel spin on FR cars; jarring ride; center of tire wears out.
Rear tire pressure lower: more over steer by incresing slip angles on most tires.
Usable range: not less then 20psi
More negative camber front: less under steer because of better lateral traction as tread is flatter on the ground under side load.
Usable range: up to 3.5 degrees negative
Symptoms of too much adjustment: poor braking; car is road crown sensitive; twitchy; front tires wear on inside edge
More negative camber rear: less over steer because of better lateral traction as tread is flatter on the ground under side load. More rear grip
Usable range: up to 2.5 degrees negative
Symptoms of too much adjustment: more over steer; car feels twitchy in back; tires wear out on inside edge; less breakaway warning when limit is exceeded.
Ride height to low (typical beginner mistake): car is twitchy with unpredictable dynamics. Bump steer make you life miserable.
Usable range: usually 1.5-2.0 inches lower then stock unless car has been modified to go lower.
Symptoms of too much adjustment: everything that could possibly go wrong: sudden over/under steer; twitchy due to bump steer; very harsh ride; premature tire wear.
Toe in – front: car is stable going straight. Turn in is average
Usable range: 0-1/8th inch
Symptoms of too much adjustment: car has slow twitchiness under braking; feels odd; kills outside edge of tires
Toe out – front: Car turns in well; works pretty well on FF car as they tend to toe-in under load.
Usable range: 0-1/4 inch
Symptoms of too much adjustment: Car is really twitchy under braking; car wanders on straight road; kills inside edge of tire
Toe in – rear: car is less likely to over steer when the throttle is lifted
Symptoms of too much adjustment: weird, slow, rocking movement in back; feels slow but still unstable; wears outside edge of tires.
Toe out – rear: Helps car rotate useful in low speed and slalom courses; very common on FF pro rally cars.
Symptoms of too much adjustment: not to good for street driving; causes lift throttle over steer; makes violent side to side rocking motions in the rear; tie wears on inside more.
Positive front caster: helps stability; suspension will get more negative camber when turning; reducing positive caster reduces steering effort. (Negative caster is not usable)
Usable range: 4-9 degrees positive
Symptoms of too much adjustment: can increase under steer especially in cars with wide low-profile tires. Can increase steering effort.
Single adjustable shock stiffer: Better turn in; better transient response; causes slower onset of over/under steer by slowing weight transfer depending on what end of the car is adjusted.
Symptoms of too much adjustment: suspension becomes unresponsive; ride gets harsh; car skips over bumps, loosing traction; Causes a big delay in weight transfer resulting in strange handling like under steer then late corner stage over steer.
Single adjustable shock softer: slower transient response; quicker onset of over/under steer
Symptoms of too much adjustment: car oscillates due to under dampened spring motion, like a boat. Car gets twitchy in turns. Feels unstable.
heres the low down on spacers [ and a little on tire profile ]
adding spacers to just the front will lower understeer, hence giving more oversteer
adding spacers to just rear will reduce, and possibly eliminate oversteer [ in most situations ]
adding them to both front and rear as a whole makes the car more stable. and still keeps the stock [ or close to stock ] response.
the problem that you ran into with the tires could souly be based on the profile and width of the tire. [ along with tire pressure ]
when you have a lower profile and a wider tred the tire is stiffer all over. [ sidewall AND tread-patch ] this means that you have a greatly reduced "slip-angle"
Hope this becomes a sticky
Old Jan 22, 2008 | 01:36 PM
Saved's Avatar
Thanks for the information my friend. This extends my understanding of suspension and how it all comes together. +1 Rep!
Old Jan 23, 2008 | 12:46 AM
i thought you said "SIMPLE."
wtf is with this long essay? no, i did not read it so can't say
if it's good stuff or not. lol
Old Jan 23, 2008 | 02:48 AM
Lyshk0's Avatar
good explanation of basic suspension adjustments
Old Feb 9, 2008 | 03:07 PM
mahout's Avatar
Too long winded.
Basically:
stiffer front springs increases understeer
stiffer rear springs increase oversteer
more toe-in increases understeer on that end of the vehicle
more toe-out increases oversteer on that end of the vehicle..
stiffer antisway bar front increases understeer
stiffer antisway bar rear increases oversteer.
antisway bars can make your car slower. They are best used only to
balance front and rear suspension cornering.
Lowering a car will not necessarily make it quicker, especially if its >0.1"
Flatter cornering is not necessarily faster; it is only if the inside
tire stays on the ground longer. 2 tires are better than 1.
wider, shorter tires are not necessarily faster.
spacers in springs stiffen the spring.
spacers on hubs increase camber on independent suspensions
increasing camber will not necessarily help cornering. about 1 degree is generally max static.
increasing caster (lean back) will generally assist cornering but not if you do too much. Stock vehicles generally run around 2 degrees; a maximum of 6 degrees is extremme and mainly for non-twisty tracks.
increasing tire pressure is same as stiffening springs
stiffer shocks are similar to stiffer springs. actually they just control stiffer springs. Failure to
match springs and shocks are a major error.
Now you know why chassis engineers have such a hard life even with computers.
Philip0021
Apr 11, 2024 10:22 PM
pentium77
May 10, 2015 10:20 AM
Myxalplyx
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Apr 22, 2015 08:45 PM
der Mond
Nov 9, 2011 10:39 PM
MajorWang
Apr 3, 2007 11:49 PM
