DIY Spoon Spoiler please.?
Old Aug 11, 2007 | 06:18 AM
fitfit123's Avatar
could anyone write a write-up on how to install the spoon spoiler?? thx
Old Aug 11, 2007 | 11:53 AM
JDMchris.com's Avatar
I run THIS
I shouldve when I installed my friends.
Anyways, with the Spoon spoiler you receive a Template that go on either ends and one in the middle. (I cut out the middle bolt so i didnt have to drill 3 holes.)
Once the Templates are in place test fit the spoiler, make sure the bolts will line up on the template.
Next you can use a punch to keep the bit in place, or just start drilling.
I would recommend gettting some touchup paint and paint the raw metal after drilling to avoid rust.
Would also recommend some doublesided tape for the middle of the spoiler altho its not required.
Open up the hatch and place the nut/washer on the bolt and tighten and your done.
Old Aug 13, 2007 | 08:42 PM
Raimondas's Avatar
Chris has it covered. Measure many times, drill once. I used all three bolts for mine, I hate tape. Also painted the nuts/washer body color. Good luck.
Old Jan 14, 2008 | 07:28 PM
saiko's Avatar
Avid FitFreak Poster
Good thing I looked for this, didn't know you had to drill to install.
Old Jan 16, 2008 | 04:49 PM
FELIXY69's Avatar
so u have to drill a big hold on the inside of the hatch so you can tighten the nut from the spoiler ?
any pics to explaine this
i got a fab spoiler and seems like the install would be the same ?
Old May 23, 2009 | 06:27 AM
axlline's Avatar
I bought one used, so no template. Could someone measure from the leading edge and the side of the hatch to the bolts so I can drill only once, thanks in advance.
Old Jul 3, 2009 | 05:27 PM
dewthedew's Avatar
how do you cover the OEM holes??
Old Jul 4, 2009 | 06:38 PM
dewthedew's Avatar
anyone?? kenken said glass glue but i dont know what that is and nobody knew at pepboys...
Old Jul 5, 2009 | 11:24 PM
wdb's Avatar
wdb
Why do you want to cover them? Aren't they hidden under the replacement spoiler? Any water that gets in should drain through the hatch body and out the holes in the bottom, none of it should come inside the car.
Old Jul 6, 2009 | 12:01 AM
dewthedew's Avatar
I thought people covered them?
Old Jul 6, 2009 | 12:19 AM
Fitftw's Avatar
for the spoon replica spoiler i redrilled holes and covered the OEM ones. no issues whatsoever yet
Old Jul 10, 2009 | 10:23 AM
pbz08gd3's Avatar
i read in kenken's cf spoiler thread that the usdm model didn't holes redrilled?! can anyone ellaborate?
Old Jul 10, 2009 | 11:50 AM
dewthedew's Avatar
you didnt read far enough into the thread.. I corrected him. You must drill
Old Jul 10, 2009 | 03:37 PM
pbz08gd3's Avatar
dirtyyyyy! and i just bought one off him. w/e no biggie ive drilled holes of all sizes in all kinds of cars. ill post pics after i get it and install it
Old Jul 23, 2009 | 01:21 PM
Mr08FiT's Avatar
So no pics and no DIY yet? it's been almost two weeks... Also does anyone have any opinions about HondaFitTuners' products...
My car will be going to the body shop next week and I want to get these peices installed while thats going on so any input would be GREAT!!!
bellzGD3
Jun 9, 2010 01:08 AM
Zangoose GD3 Blue
Jul 19, 2008 06:56 AM
petwhookie
May 14, 2008 02:55 PM
TeamStaNceFIT07
Feb 29, 2008 09:05 PM
its.ryu
13
Feb 17, 2008 06:02 PM
