DIY ATF Change
Old Jan 30, 2008 | 11:50 PM
  #41
fm2n's Avatar
Originally Posted by ToyotaLover
i did my ATF change and had my car at an angle to allow it to drain better, and i put in 3qtrs and i'm still short. I'll be going to get another quart of ATF tomorrow. it's just below the messuring bar.
You sure 3 quarts? How did you measure your ATF oil level? You have to take it out for a drive, then take a reading when the oil is hot.
Old Jan 31, 2008 | 12:41 AM
  #42
ToyotaLover's Avatar
yes i did that. drove around the block. Also checked after i drove 80 miles and it was 1/4 up the measure area.
Old Jun 1, 2008 | 09:02 PM
  #43
LeoSter's Avatar
Others are using GM synchros and say it's really good. Anyone got experience on this or comment?
Old Jun 1, 2008 | 09:08 PM
  #44
azncarbos's Avatar
I say go w/ Honda ATF.....it only about $8 a qt.
Old Aug 10, 2009 | 05:20 AM
  #45
secondspassed's Avatar
Anyone got any photos of this? The ones on the first page are done for.
Old Aug 26, 2009 | 09:57 PM
  #46
triton.'s Avatar
Why are people replacing ATF fluid at 15K miles? That seems really short period? I'm more curious than anything else.
Old Sep 28, 2009 | 06:26 AM
  #47
Master_Scythe's Avatar
err, scroll to the bottom of this page:
SYN UNIVERSAL AUTOMATIC TRANSMISSION FLUID
This stuff is not recommended for use in CVT cars, and neither is the Honda Z-1 stuff that you're talking about.
If im not mistaken, our auto FITs are constantly variable, doesnt this make it a bad thing?
Old Sep 29, 2009 | 07:15 PM
  #48
feared's Avatar
usdm fits are automatic, not cvt. jdm and edm have cvt options.
Old Sep 30, 2009 | 01:54 AM
  #49
Fair enough. it seems all the ones here in australia are listed as CVT, I cant find a single one thats not.
In reality it might be the advertisers being lazy and not telling me what the exact specs are and generalising, but atm it seems like they're all CVT
Old Oct 7, 2009 | 06:19 PM
  #50
JDMxGE8's Avatar
I'm changing every 5K. I drive a lot. Mostly city driving. Clocking 25K/year.
Old Oct 19, 2009 | 02:12 AM
  #51
RandomKoko's Avatar
on the honda manual it says first transmission oil change, change it on 60,000 then every 30,000 after.
Old Nov 4, 2009 | 02:48 AM
  #52
DOHCtor's Avatar
Some people are just more cautious then others... My ATF is becoming dark brown... i'm about to change my AFT soon!! At 30k miles or 50k Km if you prefer!Marko!
Old Nov 20, 2009 | 10:02 PM
  #53
Hapa DC5's Avatar
Agreed and that is under "severe" conditions. I wouldn't change it any more often then that.
It's up to the individual to change it sooner and given the history of Honda automatics I don't blame them. For me, I'll stick with just following that schedule.
Old Nov 21, 2009 | 03:18 AM
  #54
DOHCtor's Avatar
Well, i have 52k km on my Fit and the AT fluid is already burned... I'm gonna do a flush soon! Anyway, preventive maintenance is never done too often and transmission fluid is cheaper then a transmission!!
Marko!
Old Nov 21, 2009 | 09:45 PM
  #55
Hapa DC5's Avatar
Marko!
You're very right especially considering Honda automatics are glass.
Old Nov 24, 2009 | 12:32 AM
  #56
DOHCtor's Avatar
Yeah, it's a shame there were no more MT Fit available when i purchased mine about a year ago!
Marko!
Old Nov 24, 2009 | 04:38 AM
  #57
james123's Avatar
I used Honda's Genuine Auto Transmission Fluid. ATZ-1? forgot the exact designation. Now that I think of it, I should've used Redline, its the only Honda approved trannie fluid... or was it AMSOIL? Do some research.
Old Nov 25, 2009 | 04:31 PM
  #58
danger69's Avatar
Tip: For anyone doing their own atf change I found out that most of us are worried about if we tighten the drain bolt enough. Because if we don't it will leak and sometimes even if you do it will still drip a bit. A very simple solution is to get those gasket makers that you get from a tube. Spread a thin later on the flat size that goes to the tranny. Make sure the tranny where the bolt goes is clean of course. Try not to get any of the gasket maker on the threads. Just tighten the bolt like normal and the gasket maker will ooze out. Wipe it clean and your done.
Old Nov 25, 2009 | 05:03 PM
  #59
Selden's Avatar
Even simpler, wrap the threads with Teflon pipe joint tape. The tape adds an interference fit to the threads, so that the drain plug won't loosen up, but the Teflon makes it easy to loosen the drain plug when needed. Same technique for the engine oil drain.
Old Dec 18, 2009 | 07:21 PM
  #60
gloryhound's Avatar
hey since some of you guys replace your tranny fluid through the dipstick hole... is it safe to assume i can do the same on a manual tranny fit (2007)? cause it would be way more convenient to top up the fluid via the dipstick hole...
