camber kit questions, alignment front and rear questions and specs
Old Mar 1, 2006 | 01:55 PM
bus stop's Avatar
Anyone know if you can add a cmaber plate (like those from Cusco) onto the FIT stock suspension?
thanks
Old Mar 1, 2006 | 02:57 PM
dougiepants's Avatar
Avid FitFreak Poster
yeah you could as long as the company offers it for the Fit
Old Mar 16, 2006 | 08:48 PM
Fit7483's Avatar
Currently Cusco does not make anything in this line for the fit. They make a tower bar and a lower arm bar. For the most parts check J's Racing in Japan. They make the most stuff by far.
Old Mar 17, 2006 | 11:13 PM
Halo's Avatar
Originally Posted by claymore
You don't need a camber plate. The Jazz front suspension is adjustable up to 2degrees of pos and neg camber just by replacing the stock attachment bolts with special ones you can get from you friendly local honda dealer. You can find the procedure in the downloaded Jazz repair manual.
Do you have the part number? Thats very cool that this is a oem part
Old Mar 18, 2006 | 09:54 AM
I am sure that Skunk2, Eibach, or another company will offer one once the Fit is released...
Old Mar 21, 2006 | 11:26 AM
Halo's Avatar
Thanks man that's cool!
Old Apr 27, 2006 | 12:03 PM
akrams's Avatar
Wheel alignment
hey im running 195/55/R15 tyres on my car which comes with 175/65/R14 tyres as standard, id like to know if the Wheel alignment specs have to be changed? if so what are the specs? tks
Old Apr 27, 2006 | 02:04 PM
andyk's Avatar
if ur only changing the tyres, just do the balancing of the car. and also theres no specs on the wheel alignment, cos the main purpose is to get the wheels aligned straight. a reason to wheel align is when uv changed springs or the car doesnt drive straight. and wearing of the tyres
Old Jun 10, 2006 | 02:22 AM
fad3r's Avatar
Camber issues with lowering?
Will I be experiencing issues with camber when I drop my Fit? From what I recall, the suspension is setup different from my '96 Civic. I had to get a Skunk2 camber kit for my Civic, which was lowered with Eibach ProKit springs. If camber will be an issue with my Fit, how far can I lower my ride without affecting camber too much?
Old Jun 10, 2006 | 11:41 AM
triggerzer0's Avatar
maybe an inch, inch and a half tops
Old Jun 10, 2006 | 12:14 PM
brainfood's Avatar
All cars have camber affected by lowering. It will depend on the alignment shop and the car itself. Not everyones car will be exactley the same. But to be safe I would say an 1" or maybe 1 1/2" But depending on how you drive a little extra camber wont necessarily mean bad tire wear. I run -2.6* f and -1.4* rear on my current car but I drive it aggressivly and I get even wear. Bad Toe will destroy tires faster than any bad camber.
Old Jun 10, 2006 | 12:36 PM
Well where mine is lowered it is running about -3.5 in the front
Old Jun 10, 2006 | 06:30 PM
gsilvers's Avatar
-3.5 is probably making for an awesome turn in feel but i bet your tires and mileage will be effected just a bit.
Old Jun 10, 2006 | 11:42 PM
guywdog's Avatar
Camber adjustment DIY
I found this on the web, it's a Japanese site that has good pics about DIY camber adjustment for the Fit. I think you'll get some info from it, check it out...here..
http://www.club-miniban.com/fit_kyanba.htm
GWD
Old Jun 11, 2006 | 11:46 AM
just like adding washers to the rear of a eg or ek suspension... Hmm doesn't look to hard, but no need for that at this moment... Good find though...
Old Jun 12, 2006 | 04:53 PM
xtreme's Avatar
you should check this. its the same site translated by google.
http://translate.google.com/translat...language_tools
Old Jun 12, 2006 | 07:57 PM
Tanabe USA's Avatar
FIT Product Manufacturer
Brainfood is right on the money--
Camber doesn't affect tire wear as much as you would think-- what affects tire wear the most is the toe. A bad toe setting will wear out a tire very fast! The highest priority is to get the toe setting back to factory specs.
A smaller drop should be correctable and still within factory settings.
Old Jun 12, 2006 | 08:03 PM
kkim's Avatar
cool... thanks for the info.
Old Jun 24, 2006 | 07:58 AM
smeister's Avatar
Cool, good find! I wonder if there will be any camber issue with a 1.5" drop. hmmmm
Old Jun 24, 2006 | 02:18 PM
kkim's Avatar
Always check the alignment after you make any changes to the suspension. Most likely, you can get decent tire life if you set the toe back to spec... it will change when you drop the car.
