Weapon R street Header VS T1R Header
Old Mar 1, 2008 | 11:41 AM
t3chn0rav3rb0y's Avatar
hey, i was wondering what the differences were between the type 1 racing header and the weapon r header...gains, losses...i mean i know theres probably no losses, but whats better?? Thanks for all your replys
Old Mar 1, 2008 | 02:06 PM
suketoborudo00's Avatar
If you use the search you'd find the info but I'll answer your questions since I'm wondering the same thing
So far there is a group buy for weaponR header (as well as the dyno sheet) already which is here
The T1R header thread is here which has the dyno here
the weapon r is 200-250 and the t1r is 450-550 i believe.
Wave did a short opinion review for his J's racing header here
Most of the weapon R header owners have said they noticed an increase in torque at the low-end RPMs (also noticed in the dyno).
I think T1R is emission legal?
but the weaponR is not.
Old Mar 1, 2008 | 05:16 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
T1R will give noticeable gains compared to the WeaponR.
Old Mar 1, 2008 | 09:37 PM
thanks for the feed back...um the weapon R race header is not emissions legal, but the street header is. and i already did check both of those before hand... im just trying to ask opinions of people who have the two
Old Mar 2, 2008 | 02:21 AM
08FitSport's Avatar
I just put on the Weapon R street and I love it you can feel it the instant you touch the gas pedal. On the top end it seems the same but because the bottom is strong the top might feel mellowed out but, the dyno says 2 hp on top according to Weapon R.
Old Mar 2, 2008 | 02:44 PM
1990hondahf's Avatar
After looking at the dynos for both the choice seems clear: Weapon R.....the low end boost overall is what sells me.
here are some new dynos from weapon-r's web site:
new street header dyno:
new dyno for the RACE header....
Old Mar 2, 2008 | 08:07 PM
ah, well put to see differences in gains through dyno...so anyone else have anything?? i really wanted the T1R ones at first but then i saw such a great price for the weapon r ones
Old Mar 2, 2008 | 08:25 PM
Posts in the NUUDE
Those are older dynos for the T1R header I believe. It was redesigned.
I dont like dynapack dynos at all.
If you have the money, go for the T1R. For a cheaper and nice header, I like the DCSports. And then some like the Megan over the DCSports.
Old Mar 3, 2008 | 10:11 AM
nice...can i get some feed back from someone who has T1R headers?
Old Mar 4, 2008 | 09:23 PM
ldweng's Avatar
I am very pleased with my T1R header. It is a fine piece of work. I waited a long time for the WR header because of the 4-2-1 design and low price, but it sort of pis*** me off that it didn't fit properly and they thought that was OK. I also was thinking about FI so I liked the larger pipes.
I have a HFP exhaust and it really reduced the booming between 2 & 3 M revs. My gas mileage went up about 10%. There was comment that the larger tubing could lean out the mix and that is probably true, but it has more low end so I also spend more time in a higher gear than before.
I don't know if you can justify the extra cash, but I have no second thoughts.
Old Mar 7, 2008 | 10:15 AM
does anyone else know of the weapon r headers not fitting?
Old Mar 7, 2008 | 12:54 PM
08FitSport's Avatar
The Weapon R flange to the down pipe is about 5mm short so the bracket to the header to transmission is slightly off. The bracket uses a thick washer that I moved between the header and bracket and no problems. The header is very solid so WR says you can omit the bracket. I just used it because it's there.
Old Mar 8, 2008 | 01:14 AM
thanks! um well anyone have anything else to say about both headers...people who have each headers. THANKS!! GAINS
thanks! um well anyone have anything else to say about both headers...people who have each headers. THANKS!! GAINS LOSSES LOSSES ANYTING!
Old Mar 8, 2008 | 02:54 AM
AJ PwR Jr.'s Avatar
Former Vendor
The T1R header has 38mm and each tubing is close to equal length. The header is built and aimed for hp at deaily driving usable ranges. As you can see from the dynoplot, the power kicked in at very low rpm which a lot of other headers will not do on the market.
Well developed and high quality products cannot be made cheaply but we tried to maintain the price as low as possible already.
Good luck in choosing the header
Thanks
Ben
Old Mar 8, 2008 | 07:33 PM
thanks ben! well anyway..i guess i will go with the T1R ...
Old Mar 14, 2008 | 02:09 AM
updated dynos FYI
Old Mar 14, 2008 | 10:30 AM
Illusive's Avatar
It's completely up to you. The price for the T1R header is greater than the Weapon R header, but you know what you'll get from T1R. There is a reason why a lot of us here on the forum use their products and consistently give great marks to their products. I would definitely save up and spend the extra money to get the T1R headers.
Old Mar 14, 2008 | 09:55 PM
Arisenfury's Avatar
Weapon*R here. Aside from the support bracket not matching up it works wonders. Car is much more driveable.
Old Jul 18, 2008 | 03:32 PM
overheatedfit's Avatar
both headers are not carb legal right.
