jdm turbo kits
Old Mar 16, 2008 | 12:49 AM
Combo's Avatar
jdm turbo kits
say what are the differences of the jdm turbo kits vs usdm turbo kit? the piping should be the same since the engine compartment of the two are same...im not sure of the throttle but does that affect the kits?
Old Mar 16, 2008 | 03:01 AM
claymore's Avatar
The piping is not the same as the location of the DBW throttle body is a bit different and the ECU controller has to be made to accommodate the DBW system. And except for the most recent ones the USDM intake was different than the rest of the world.
Old Mar 16, 2008 | 09:34 PM
NotraFit's Avatar
man u sure about dat? cos i heard dat it wont be a proble thru Ben
Old Mar 17, 2008 | 12:30 AM
AJ PwR Jr.'s Avatar
Former Vendor
The JDM Turbo kit's are identical but you have to expect modifications before you can install to the USDM Fit.
Old Mar 17, 2008 | 02:21 AM
claymore's Avatar
How can something be called "Identical" which means "exactly the same" and in the same sentence state that you have to modify it to install it on the USDM Fit?? Are you saying the ECU controllers are identical also??
Old Mar 17, 2008 | 03:13 AM
Combo's Avatar
thanks for answering, Ben
could you expand your answer? i.e. which part/s need modification? the ecu tuning i'd imagine would be quite different rite? and what else?
Old Mar 17, 2008 | 03:22 AM
AJ PwR Jr.'s Avatar
Former Vendor
Isn't identical means look a like Maybe I should call it similar.
JDM ECU and USDM ECU looks identical (similar) too but the pin out diagram is totally different. The JDM pre-tuned map will make the USDM Fit runs a lot leaner.
Inercooler pipes, intercooler mounting , oil return hose.....etc has to be worked on.
Garage R
Aug 4, 2025 09:39 PM
The Assassin
13
Nov 19, 2010 03:33 PM
FELIXY69
Feb 8, 2008 10:38 AM
osborne
Aug 14, 2007 10:28 AM
007Fit
Jun 28, 2006 10:42 AM
