Stop Rubbing. Rear Bumper Screw Delete
Old Mar 19, 2008 | 07:55 PM
MarkyMark's Avatar
I was rotating the tires on my wife's Fit tonight and remembered a couple people on here complaining about their rear tires rubbing. So, I thought I'd be a nice guy and take a picture of the way I got rid of the rear screw that holds the bumper on.
All I did was take the screw out and grind down the mounting tab with a dremel, and then rolled the fenders. Then I just drilled a 1/8 inch hole through the bumper and what was left of the mounting tab on the fender. Next, to prevent rust, I went over the now exposed metal surfaces with some NHBP touch up paint I had in the garage for my Accord. Then I just ran a zip tie through the holes to secure the bumper.
Old Mar 19, 2008 | 08:45 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Good mod. The little bit of rolling I see looks good.
You see that black plastic clip/liner behind the tie you added? Thats what I was rub on. My Enkeis actually broke that piece on both sides of my Fit. My rear bumper rubbed itself away.
I can pull the corners of my rear bumper off with no effort.
Old Mar 19, 2008 | 09:54 PM
MarkyMark's Avatar
I'm going to switch to 17x8 +35 or 16x7 +15, not sure yet. I wonder if that will happen to me?
Old Mar 19, 2008 | 09:56 PM
Posts in the NUUDE
Probably? No way to know unless you do it. 17x8's would be pretty sick.
Old Mar 19, 2008 | 10:06 PM
StormSilverGD3's Avatar
Just curious, but, do you think rolling the fender had more of an effect than removing the screw?
Old Mar 20, 2008 | 01:10 AM
doctordoom's Avatar
Supervillain
and another question, does the bumper flap around at high speeds now?
Old Mar 20, 2008 | 07:39 AM
MarkyMark's Avatar
After I rolled the fenders, it still rubbed on the screw, so I would say removing the screw had more of an effect.
Nope, I have the zip tie pretty tight.
Old Mar 20, 2008 | 07:55 AM
fitoromocto's Avatar
You should expect that this question was coming," You say removing the screw had more of an effect. do you feel that after the srew mod it is still nessecary to rolled the fender?
Old Mar 20, 2008 | 01:32 PM
MarkyMark's Avatar
That really depends on the wheel and tire combination you're running, ride height, and alignment settings, so it's hard to say yes or no. My best advice would be to eliminate the screw first, and then test it out. If you're still rubbing, roll the fenders.
Old Mar 20, 2008 | 06:24 PM
Posts in the NUUDE
Mine doesnt, and I dont have anything holding it on or inward.
JohnnyAction
Mar 14, 2012 11:35 PM
GD3_JDMLIFE
SoCal Classifieds
Mar 24, 2011 05:46 AM
Marrk
Dec 18, 2010 08:48 PM
diedwater
Sep 19, 2008 08:00 AM
FitPilot
Aug 29, 2008 02:27 PM
